POV-Ray : Newsgroups : povray.binaries.animations : Re: Flood of Blood (1.24 mb) Server Time
3 Jul 2026 18:10:12 EDT (-0400)
  Re: Flood of Blood (1.24 mb) (Message 11 to 15 of 15)
Subject: Re: Flood of Blood (1.24 mb)
Date: 17 Oct 2001 14:30:39
Message: <3bcdce4f$1@news.povray.org>
Right. But I think this would slow things down...
Jonathan.
"Trevor Quayle" <Tin### [at] hotmailcom> ha scritto nel messaggio
news:3bcdcd96$1@news.povray.org...
> 3^3 -1 (cubes that share faces, edges and corners)
> -tgq
> "JRG" <jrg### [at] hotmailcom> wrote in message
> news:3bcdcbde@news.povray.org...
> > 26?
> > Jonathan.
> > news:3bcdc957$1@news.povray.org...
> > > Actually you should check the 26 cubes immediately surrounding the
cube
> in
> > > question as well, otherwise particles at the very edge of one cube
> > wouldn't
> > > be influenced by particles at the very edge of the next cube
> > > -tgq
> > > "Chris Jeppesen" <chr### [at] digiquillcom> wrote in message
> > > news:3bcdc15c$1@news.povray.org...
> > > > Well, the basic alogrithm is to find the closest neighboring
particle,
> > and
> > > > if it is within a certain distance, generate a force towards this
> > nearest
> > > > neighbor. The slow O(N^2) part is finding the nearest particle.
> > > > What if you chopped up the space into cubes, and only looked for a
> > nearest
> > > > neighbor in the same cube? I assume that somewhere deep down in your
> > > > simulation is a 1-dimensional array representing the particles.
> > > > Suppose you divided the space into 10x10x10 cubes, and had a
> > 4-dimensional
> > > > array Neighbors[10][10][10][N_PARTICLES]. When the physics loop
> starts,
> > > the
> > > > array is cleared. When each particle position is updated, calculate
> > which
> > > > cube it belongs in, say <4,5,6> and write that into
> Neighbors[4][5][6].
> > > Now
> > > > when it comes time to calculate, for each particle only check for
its
> > > > nearest neighbor in the same neighbor cube. This could reduce time
to
> > > > O(1000*(N/1000)^2).
Date: 17 Oct 2001 14:35:11
Message: <3bcdcf5f$1@news.povray.org>
Yes, but it would also prevent the particles from forming into cubes which
fall apart from each other.  You would get cohesion within each spatial
cube, but not between each cube.
-tgq
news:3bcdce4f$1@news.povray.org...
> Jonathan.
> > -tgq
> > > 26?
> > > Jonathan.
> cube
> > in
> > > wouldn't
> > > > -tgq
> particle,
> > > and
> > > nearest
> > > nearest
your
> > > 4-dimensional
> > starts,
> > > > the
calculate
> > > which
> > Neighbors[4][5][6].
> > > > Now
> its
> to
> > > > > O(1000*(N/1000)^2).
Date: 18 Oct 2001 02:44:59
Message: <3BCE7721.14B3AD2B@yahoo.com.au>
I recently decided to do my own (unfinished) particle system (when it's done,
I might call it... the wheel :), so that I can do this sort of effect. I have
found that a block map is tolerably fast even when checking the contents of 27
cells.
    Getting the effect of cubes ignoring one another can occur if you only check
one cell, but this behaviour is dependent on the relative magnitudes of the
particle-particle interactions, and their velocities.
    I hope your system is entertaining you JRG, I know mine is.
MJL
> -tgq
Date: 18 Oct 2001 03:15:49
Message: <3bce81a5@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message news:3bcdbc8c@news.povray.org...
> Do you know a *fast* way to do that in POV SDL? As I said elsewhere, it
> would be really a simple implementation, but it would be *extremely* slow to
> compute with so many particles. I could consider to implement non persistent
> (sp?) particles to reduce the number of particles per frame though... any
> help?
I would just place a huge squashed blob just beneath the surface with a small
strength value. But that wouldn't be perfect...
- Nekar
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 19 Oct 2001 07:47:31
Message: <3BD012A7.572E8240@gmx.net>
Looks very nice, ammazing what one can do with pov. I agree with the earlier
comments that the particle should interact with the surface as well. I'm sure
you will find a solution that is fast enough.
One thing I would like to mention however is that everyone (You, Rune and Mark
James Lewin apperently) are all writing particle systems. Wouldn't it be an
idea to combine al these efforts?
Just my two cents....
ps. Yes I know it is very rewarding writing your own.
JRG wrote:
> See same thread in p.b-i.
> I know I can get better compression with divx, but the quality was *really*
> poor. Is there anyone who can drive me through all those encoding options?
> TIA.
