POV-Ray : Newsgroups : povray.binaries.animations : Differenced isosurface problem Server Time
18 Jun 2026 07:27:46 EDT (-0400)
  Differenced isosurface problem (Message 1 to 9 of 9)
Subject: Differenced isosurface problem
Date: 6 Oct 2001 07:31:40
Message: <3bbeeb9c@news.povray.org>
I don't know what I'm doing wrong with this scene. I created an isosurface
(the same you can see in the previous animation I posted) and differenced
half of it from a plane.  When observed from sideways the result looks fine,
but as I rotated it, a large white area appeared. Well, an animation with 60
frames is woth 60000 words, so go ahead and take a look.
If someone knows what I am doing wrong, please tell me. Oh, and if it is too
obvious, feel free to nag me from here to Kabul.
Here is the scene. It uses Ingo Janssen's "param.inc":
light_source { <0, 100, 00> color rgb 1.0 }
light_source { <0, 10, -100> color rgb 1.0 }
  location  <0.0 , .10 , -10.0>
  look_at   <0.0 , 0.0 , 0.0>
  angle 15
background { rgb 2 }
#declare Fx = function(u, v) {sin(u)*sin(v) +sin(20*v)*0.05}
#declare Fy = function(u, v) {cos(u)*cos(v) +cos(20*u)*0.05}
#declare Fz = function(u, v) {sin(v)}
#declare Umin = -1*pi;
#declare Umax =  1*pi;
#declare Vmin = -1*pi;
#declare Vmax =  1*pi;
#declare Iter_U = 100;
#declare Iter_V = 100;
#declare WriteReadMesh = "Parafun.msh"
#include "param.inc"
Parametric()
#declare Parafun = difference {
  object {
    Surface
    rotate y*90
    rotate x*90
      pigment { color rgb z }
      finish { specular 1 }
  plane { x 0 }
  rotate z*-90
  translate y/2
object {
  Parafun
  rotate x*360*.clock
Any help will be greatly apreciated.
Thanks,
Ruy
Download 'Parafun.mpg' (543 KB)
Subject: Re: Differenced isosurface problem
Date: 6 Oct 2001 07:49:02
Message: <3bbeefae$1@news.povray.org>
Don't know for parmetrics but perhaps you have to add max_trace or
all_intersection, as with isosurfaces. Without this, pov will only calculate
the first found intersection, which is cut of by the CSG.
Marc-Hendrik
Date: 6 Oct 2001 08:12:18
Message: <3bbef522@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> escreveu na mensagem
news:3bbeefae$1@news.povray.org...
calculate
> Marc-Hendrik
Actually the isosurface is first transformed into a mesh2 object by Ingo's
include file. Only then it is differenced from the plane. Do max_trace and
all_intersection interfere with meshes at all?
Date: 6 Oct 2001 08:19:02
Message: <3bbef6b6$1@news.povray.org>
Ruy schrieb in Nachricht <3bbef522@news.povray.org>...
mensagem
>calculate
>> Marc-Hendrik
No. Has to be something else.
Date: 6 Oct 2001 08:41:10
Message: <3bbefbe6@news.povray.org>
Oh wait! You make a CSG with a mesh? That won't work. MegaPov  had Solid
triangle meshes where you could specify an inside-vector, but that seems not
to exist in v3.5 anymore. Without you can't difference or intersect a mesh.
Or did that change?
Marc-Hendrik
Date: 6 Oct 2001 08:57:16
Message: <ot5RmDAdkvv7EwaO@econym.demon.co.uk>
When you use Ingo's "param.inc" file, it converts your functions into a
*mesh2* object rather than an actual isosurface. Mesh2 objects can't be
used in differences.
The docs say:
   There are six totally thin, finite objects which have no well-defined
   inside. They are bicubic patch, disc, smooth triangle, triangle,
   polygon and mesh / mesh2. They may be combined in CSG union but
   cannot be used in other types of CSG (or inside a clipped_by
   statement).
Mike Williams
Gentleman of Leisure
Date: 6 Oct 2001 13:26:31
Message: <3bbf3ec7@news.povray.org>
> The docs say:
>    statement).
> Mike Williams
Well, too bad. Anyway, parametric equations give us such amazing flexibility
that it didn't take 3 minutes before I got even better "sblorgles" just
playing with the parameters.
Thanks for the pointer.
Ruy
Date: 9 Oct 2001 14:13:17
Message: <3bc33e3d@news.povray.org>
Can anyone tell me where a copy of Ingo's "param.inc" can be found?  Thanks.
Cris Williams
"Mike Williams" <mik### [at] nospamplease> wrote in message
news:ot5### [at] econymdemoncouk...
isosurface
fine,
60
too
> The docs say:
>    statement).
> Mike Williams
Date: 9 Oct 2001 14:35:59
Message: <3bc3438f@news.povray.org>
Look in Povray.binaries.scene-files for "param.inc".
Marc-Hendrik
