POV-Ray : Newsgroups : povray.binaries.animations : Time Dependent SE in 2D. (URL) Server Time
19 Jul 2025 08:29:50 EDT (-0400)
  Time Dependent SE in 2D. (URL) (Message 1 to 7 of 7)
Subject: Time Dependent SE in 2D. (URL)
Date: 5 Aug 2001 07:07:34
Message: <3b6d28f6$1@news.povray.org>
Here's a simulation of a wave-packet in two dimensions scattered from a
potential resembling a wall with a slit, very much like the famous
diffraction-experiments seen with electron beams. This is kind of a test
rendering; initial conditions are like kind of arbitrary. I am working on a
visualization project at the University of Oslo, and this is some of the
work I am doing there.
I used the Leapfrog-Algorithm in C++ to simuate the wave-function on a
200x200-grid of doubles. The output is hundreds of PPM-files used as
height-fields.
Comments are welcome! What can be done to perhaps make it even more
illustrating? As for now, I am quite happy with the texture of the wave, but
as I said, comments/suggestions are welcome! :)
URL: http://www.fys.uio.no/~simenkva/animations/diffr.mpg
regards,
Simen Kvaal.
Simen Kvaal, Student at the faculty of
mathematics and natural sciences, University
of Oslo, Norway.
e-mail: sim### [at] studentmatnatuiono
web: http://www.uio.no/~simenkv/
Subject: Re: Time Dependent SE in 2D. (URL)
Date: 5 Aug 2001 09:24:28
Message: <Xns90F49CBCE93D1seed7@povray.org>
> wave, but as I said, comments/suggestions are welcome! :)
Fascinating.
If the hight of the wave has any importance in the experiment, maybe
add a slight gradient. Maybe make the green walls of he slit (semi)
transparent.
Ingo
Date: 5 Aug 2001 09:55:01
Message: <MPG.15d76efbb5c70419989824@NEWS.POVRAY.ORG>
In article <3b6d28f6$1@news.povray.org>, Simen Kvaal says...
> height-fields.
What happens after the reflection that makes the energy seem to break up
in small parts the size of the grid squares?
On the whole it is great: makes the quantum theory a little 'visible' to
the layman. :)
Regards,  Sander
Date: 6 Aug 2001 07:15:12
Message: <3B6E7C40.D121CD61@fys.uio.no>
It stems from interference, and the match with the grid might be
caused by that the speed of the wave happens to be an integer. (The
grid lines have integer spacing; 2.)
Also remember that the wave equation is slightly different from the
usual "surface" or "water" equation, so the behaviour is not the same.
Simen.
Date: 6 Aug 2001 07:16:32
Message: <3B6E7C90.A1C9E466@fys.uio.no>
ingo wrote:
> Fascinating.
> transparent.
Thanks for the suggestions!
I've tried several things with the barrier, but I find it a bit
confusing. A slight gradient is a possibility; I'll try some
variations and maybe post some stills if it turns out better.
Simen.
Date: 13 Aug 2001 21:46:07
Message: <3B788302.8BE73E58@mail.com>
Simon -
I'm a Ph.D. student in Physics at the University of Nebraska.  I'm
always looking for cool visualizations of quantum mechanics, and I'm
pretty impressed by this animation!
I've experimented with using color coding to denote the phase of the
wavefunction, and it seems to work pretty well.  Is that something you'd
be interested in doing?
Also, the thing that interests me the most right now is visualizing the
time dependent scattering of a photon pulse on an atom or something like
that... but who has the time?
- Ben
Date: 9 Nov 2001 04:36:56
Message: <3BEBA3B9.E299F770@durham.ac.uk>
It wouldn't make it any more viewabel, but it would make it pretty - why
not try a water/glass transparent texture for the heightfield ?
> height-fields.
> regards,
> Simen Kvaal.
> of Oslo, Norway.
Oliver Wood
University Of Durham
http://www.dur.ac.uk/o.e.wood/
