POV-Ray : Newsgroups : povray.binaries.animations : even more balls Server Time
10 Apr 2026 21:48:28 EDT (-0400)
  even more balls (Message 1 to 10 of 19)
Subject: even more balls
Date: 1 Jun 2001 13:51:11
Message: <3b17d60f@news.povray.org>
I fixed some more bugs in the physics, so I decided I'd give them a thorough
test. I left this one running overnight and today while I was at work, that's 17
hours, just to see how it ran with a much larger number of balls. It's pretty
convincing apart from a couple of balls getting pushed through the walls :)
Next I think I might have a go at varying the radius and weight of each ball.
Tek
http://www.evilsuperbrain.com
Download 'MOTION.MPG' (335 KB)
Subject: Re: even more balls
Date: 1 Jun 2001 14:39:10
Message: <3b17e14e$1@news.povray.org>
After about the 5th ball dropped (or so) a couple of balls seem to "slide"
to the left in midair before they hit the ground.
news:3b17d60f@news.povray.org...
thorough
that's 17
pretty
ball.
> Tek
Date: 1 Jun 2001 16:02:10
Message: <MPG.1582131d224653b69897b1@NEWS.POVRAY.ORG>
In article <3b17e14e$1@news.povray.org>, Patrick Dugan says...
I looked at all the images in detail (the motion blur made that
difficult), but as far as I can see it is all OK, the 'slides' you see
were 2 balls falling and hitting each other in mid air - I think.
To me it is astonishing real: excellent!
Regards,  Sander
Date: 1 Jun 2001 17:49:10
Message: <3b180dd6@news.povray.org>
I hate to contradict you, but I think Patrick might be right. I have a slightly
dubious piece of maths that alters the effects of gravity after a collision
(well I /thought/ it worked). I guess those two balls are just created too close
together then they fall constantly colliding. I've now fixed it in a low-tech
way by making sure balls aren't created so close together ;)
Thanks :D
Tek
Date: 1 Jun 2001 19:37:09
Message: <3B182911.26012826@qwest.net>
watched it for about five minutes straight looping...
noticed balls would pick up energy sometimes almost as
if the floor were "sprung."  sorta eat- also noticed
one ball in back right corner got "caught" somehow and
gained energy somehow until it winked out or stopped
cold- couldn't tell.
overall VERY neat simulation!
CG images, *obscure* home-brewed graphics utils, and
animation
http://www.users.qwest.net/~dearmad
Date: 1 Jun 2001 19:49:03
Message: <3b1829ef@news.povray.org>
wow - how about doing these higher res - (like double)
PGP Public Key
Date: 1 Jun 2001 23:39:19
Message: <3b185fe7@news.povray.org>
Hmm... I think that's just when there's a series of collisions (so whilst one
ball may gain loads of energy some others should lose it). Every
collision -should- lose a little energy. Still, I'll look for that.
> also noticed
Yup, I spotted that one. it's fixed now :)
Thank you!
Tek
Date: 1 Jun 2001 23:42:21
Message: <3b18609d@news.povray.org>
I would do, but my computer's been having problems recently due to overheating
(one of the many fans broke). I don't fancy leaving it on for too long until
I've fixed it.
Besides, I'm still improving the simulation. I'll do a high-res one once I'm
finished, if I ever am ;)
Tek
Date: 2 Jun 2001 04:43:20
Message: <MPG.1582c587e1cf94489897b5@NEWS.POVRAY.ORG>
In article <3b180dd6@news.povray.org>, Tek says...
OK, I'll stop defending your work in future :)
Regards,  Sander
Subject: bigger version (555k)
Date: 2 Jun 2001 14:03:28
Message: <3b192a70@news.povray.org>
I changed my mind! Here's a bigger render, from a nicer camera angle.
Unfortunately the motion blur isn't quite high enough quality for this
resolution, but other than that I'm very happy with it :)
A change to the physics now means that the balls can escape through the open
side of the box, which means the render has less things to draw, so this 200
frame higher-res version took a /mere/ 6 hours!
Tek
Download 'MOTION.MPG' (556 KB)
