POV-Ray : Newsgroups : povray.binaries.animations : even more balls Server Time
12 Jun 2026 08:07:38 EDT (-0400)
  even more balls (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: bigger version (555k)
Date: 2 Jun 2001 14:03:28
Message: <3b192a70@news.povray.org>
I changed my mind! Here's a bigger render, from a nicer camera angle.
Unfortunately the motion blur isn't quite high enough quality for this
resolution, but other than that I'm very happy with it :)
A change to the physics now means that the balls can escape through the open
side of the box, which means the render has less things to draw, so this 200
frame higher-res version took a /mere/ 6 hours!
Tek
http://www.evilsuperbrain.com
Download 'MOTION.MPG' (556 KB)
Subject: Re: bigger version (555k)
Date: 2 Jun 2001 17:29:42
Message: <MPG.158379281102f28f9897ba@NEWS.POVRAY.ORG>
In article <3b192a70@news.povray.org>, Tek says...
> Tek
Even more impressive! A pity that rendering an animation still is so
very time consuming; I would like to see more of it :)
Regards,  Sander
Date: 2 Jun 2001 19:49:06
Message: <3b197b72@news.povray.org>
Well, I've rigged it up so I can continue renders from any frame. Now I'll just
run it in the background whenever my computer's on :) I'll post the results once
I have some (or a link if the file's too big).
Tek
Date: 2 Jun 2001 20:28:35
Message: <3b1984b3$1@news.povray.org>
That's superb! - fascinating how the balls seem to collect in one corner (or
is that your physics model :)
PGP Public Key
Date: 2 Jun 2001 21:17:44
Message: <3b199038@news.povray.org>
> That's superb!
Thank you!
I think that's just coincedence. I'm continuing the render at the moment, it's
got 36 frames further than the last one I posted, and it looks like that clump
of balls has moved now :)
Tek
Date: 2 Jun 2001 23:44:50
Message: <3b19b2b2@news.povray.org>
Purty!
Date: 3 Jun 2001 01:21:52
Message: <3b19c970$1@news.povray.org>
Liked this thing from the beginning.  Are rotations involved at all?  Seeing
as how several of those fall, bounce off the wall and exit nearly
identically it would seem they don't have rotational friction.  Or at least
not randomized rotation.  Or you already are and I missed that fact.
Bob H.
Date: 3 Jun 2001 07:38:30
Message: <3b1a21b6@news.povray.org>
Nope, you're right. Well spotted. In fact there's no rotation or friction in the
system at all. I figured I could get pretty good results without it.
Tek
Subject: Re: even more balls
Date: 4 Jun 2001 06:00:00
Message: <3b1b5c20@news.povray.org>
Great ... and now, make it loopable ;-)
background{rgb 1}camera{location<1,5,-2>look_at 0}#macro m(a,b,i)#local d=(b-a)
/8;#local e=vcross(d,y);#if(i)m(a-e,a+e+2*d,i-1)m(a+e,a+2*d-e,i-1)m(a+3*d-e,a+e
+3*d,i-1)m(a+3*d-e,a+5*d-e,i-1)m(a+6*d-e,a+e+6*d,i-1)m(a+8*d-e,a+e+8*d,i-1)#else
cylinder{a,b,vlength(d)/3 pigment{rgb 0}}#end#end m(-4*x,2*x,4) // Jan Walzer
Date: 4 Jun 2001 08:09:54
Message: <3b1b7a92$1@news.povray.org>
Very nice!
There is something wrong with that ball, which rests in the corner, while it
got hit by several other balls. It jumps up at the end, but I really think
it should get some impulses from the other balls. Perhaps, it's just me,
though ...
I like the atmosphere of the colors used!
Marc-Hendrik
Tek schrieb in Nachricht <3b192a70@news.povray.org>...
open
200
>Tek
