POV-Ray : Newsgroups : povray.binaries.animations : Media Fire take 1 (230kau) Server Time
3 Jul 2026 23:08:26 EDT (-0400)
  Media Fire take 1 (230kau) (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Media Fire take 1 (230kau)
Date: 4 Apr 2001 18:07:04
Message: <3acb9b08@news.povray.org>
This looks like a gigantic candle. Pretty, though.
Date: 4 Apr 2001 19:21:17
Message: <3acbac6d@news.povray.org>
Maybe my imagination (it *is* late at night right now), but I think I see a
ghostly face in the top of the flames, just for an instant.Strange artifacts
though.
I wonder what the overall effect would be if you had two or three of these
flames side by side, but close enough to look as though they were part of
the same fire, each having different turbulence settings, and each
interacting. AFAIK, fires like the one in your animation don't have a single
flame 'source', instead having their flames distributed over a circular
area.
Just a thought. Good work.
Andy
"Rune" <run### [at] inamecom> wrote in message
news:3acb8527@news.povray.org...
> Because the glow fire works on a black background only I've had to
> experiment with a media solution. This is the result so far. It's not
> perfect but it's a start.
> Media has both advantages and disadvantages compared to glows. Media works
> on all backgrounds but it is also slower. With media one have greater
> control over every aspect, but that also make it more difficult to
control.
> Media is more precise (for example the turbulence is really 3D), but
because
> of the complexity, errors are also more likely to occur. (There are a few
> annoying artefacts in the media in this animation and I don't know what
> causes it.)
> In this animation I tried placing the fire in a simple scene, and I think
it
> works well. I also tried attaching a light_source to 20% of the particles
> (there are about 30 particles alive at a time), but I don't think it works
> particularly well. The fire doesn't flicker enough to the sides to make it
> worth while.
> Anyway, as always I'd really appreciate your feedback!
> Rune
> \ Include files, tutorials, 3D images, raytracing jokes,
> / The POV Desktop Theme, and The POV-Ray Logo Contest can
> \ all be found at http://rsj.mobilixnet.dk (updated March 29)
> / Also visit http://www.povrayusers.org
Date: 5 Apr 2001 02:47:16
Message: <3acc14f4@news.povray.org>
Good work there.
The lighting has quite a striking effect there. Nice.
Maybe if you add smoke the artefacts wouldn't be so obvious, but that
wouldn't really solve the problem...
Real flames are transparent at the centre. Do you think you could try that?
Nekar
control.
because
> causes it.)
it
> worth while.
> Rune
Date: 5 Apr 2001 07:38:15
Message: <3acc5926@news.povray.org>
> control over every aspect, but that also make it more difficult to control.
> Media is more precise (for example the turbulence is really 3D), but because
> causes it.)
Yeah, those artifacts are really strange.  You're using a blob, right?  Have
you tried looking at the shape of the blob in those frames?  Is it really
the media being clear, or is it the media being thin in those spots?  For
some reason (shape of the spots?), I think it might be the former, and if
so, that can be fixed.  If the latter, maybe different turbulence would
help.
> In this animation I tried placing the fire in a simple scene, and I think it
> worth while.
I thought the flickers were really nice, personally, especially on the back
stones.
I agree with others about the multiple sources.  That might also help the
flicker.  However, when doing multiple sources, overlapping might be a
problem (unless they're a single media object, which might not be too bad)
Also, the flames to the outside get drawn in towards the center somewhat,
which might be tricky to model, although an attraction force between the
particles may be sufficient.  In fact, that might be something you want to
do anyway, as the current flame is a little too broad at the top.  The point
effect is due to the hottest parts rising faster and the surrounding area
getting drawn in, after all.
Geoff
Date: 5 Apr 2001 12:14:54
Message: <3acc99fe@news.povray.org>
"Christoph Hormann" wrote:
> Quite impressive, as already said some more fire like
> structures would be good, meaning sharper border and
> somehow more splitting it up into flames.
I suppose I came closer in the "Glow Fire take 3" approach?
This media is difficult to control! :(
> The moving shadows are looking interesting, maybe
> radiosity (or even only radiosity lighting) would be
> worth trying.
No thanks, not right now.
Radiosity in stills is slow enough for me! ;)
Rune
Date: 5 Apr 2001 12:14:59
Message: <3acc9a03@news.povray.org>
I'll remember when I need to make a gigantic candle! ;)
Rune
Date: 5 Apr 2001 12:15:05
Message: <3acc9a09@news.povray.org>
> three of these flames side by side, but close enough to look
> as though they were part of the same fire, each having
> different turbulence settings, and each interacting. AFAIK,
> a circular area. Just a thought.
I'll try some of your ideas.
It should all be possible with just a single emitter though.
>  Good work.
Thanks!
Rune
Date: 5 Apr 2001 12:15:10
Message: <3acc9a0e@news.povray.org>
"Nekar Xenos" wrote:
> Good work there.
Thanks!
I'm not quite satisfied with it myself.
Are you sure? I mean, a candle light is, but not a camp fire I believe.
Reference images would be great.
Rune
Date: 5 Apr 2001 12:15:22
Message: <3acc9a1a@news.povray.org>
Yeah.
No. I considered using a blob with a blob_pattern density but had to reject
the idea, as it doesn't allow me to assign separate turbulence to the
individual particles, which I need to.
I'm using a merge of spheres. Inside the merge is a single interior with
multiple media statements, one for each particle.
Using a union of spheres forces a whole lot of samples to be taken because
of the many intersections; that's why I use merge.
When using merge I can't place the media inside the individual spheres (that
doesn't work correctly). So I place all the media statements in the parent
object (the merge).
Using this method is fairly fast.
> especially on the back stones.
I think it would be both faster and prettier to use just one light_source
(possible area_light) and manually moving it around a little and change the
brightness.
Instead of using multiple sources I could use one source that moves around
in a circle really fast (currently possible) or a source that is an object
(not yet implemented).
> when doing multiple sources, overlapping might be a problem
I'm already using overlapping media if that's what you mean, and I've used
it often before. Could that be causing the artefacts?
> center somewhat, which might be tricky to model, although
> an attraction force between the particles may be sufficient.
Sorry, I've decided not to implement any kind of inter-particle forces in my
system.
> In fact, that might be something you want to do anyway,
Real camp fire isn't necessarily cone-shaped is it?
Thanks for the feedback!
Rune
Date: 5 Apr 2001 12:38:33
Message: <3acc9f89@news.povray.org>
> Yeah.
Ok, I thought those artifacts looked like spherical shapes.  I really think
if you do a fast anim of the spheres themselves (opaque, in other words)
that you'll find the same holes in the surface.
Yeah, and it should work, with some fine tuning.
> brightness.
Hmm, maybe take a weighted average of the particles' locations would work.
Ie, weight based upon the strengths (amount of emission) of the individual
bits.
Or maybe use two lights (areas), one large one near the bottom as above, but
one up higher that only uses the highest points.  That is where most of the
flicker comes from, anyway.
Same effect, really.
No, the artefacts are caused (well, assuming I'm right) by places outside
the container.
> system.
Drat. :/
Not really, no.  More of a teardrop.
Geoff
