POV-Ray : Newsgroups : povray.binaries.animations : Waterfall (119kbbu) Server Time
3 Jul 2026 22:44:54 EDT (-0400)
  Waterfall (119kbbu) (Message 11 to 20 of 20)
Subject: Re: Waterfall (119kbbu)
Date: 23 Feb 2001 12:57:57
Message: <chrishuff-1BD532.12570223022001@news.povray.org>
In article <3a969cf1@news.povray.org>, "Rune" <run### [at] inamecom>
wrote:
> I thought so too at first, but it doesn't appear to work that way. The
> particles come very quickly to a complete stop. :(
You need to give the particles a very *high* rebound in order for them
to keep going...I think the only good way to do this will require
inter-particle forces and/or particle-ground forces. I've done a system
like this before which didn't do any collision detection, just
avoidance: I had the ground repel the particles, so they hovered
slightly above it and constantly slid downhill, taking the easiest path.
Christopher James Huff
Date: 23 Feb 2001 14:03:37
Message: <3a96b409@news.povray.org>
Hi Chris, I downloaded MegaPovPlus, the documentation and the sample files.
The executive worked fine, but more than half of the particle_system sample
files generated errors and the help files were in an unknown file format; I
presume they are not for Windows.
Is there any chance of getting the scene files working and have
documentation for Windows made (html will be fine) ?
> I posted some images and animations on these groups a while ago
My cache doesn't go back that far. Is there anywhere else I can see sample
animations?
> and somebody used it in an image of some odd robots spraying
> stuff at a mutated rug/chicken thing.
Yes, I remember that one. By Margus Ramst IIRC.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
Date: 23 Feb 2001 14:24:48
Message: <3a96b900@news.povray.org>
> order for them to keep going...
Yes, but then it wouldn't be flowing.
Not an option in this case.
I've experimented a little with this. So far with no success, but I still
have a few ideas to try out.
Does the particle_system patch support flowing? If yes, how is it
implemented?
Rune
Date: 23 Feb 2001 14:51:59
Message: <chrishuff-AE5FFE.14510023022001@news.povray.org>
In article <3a96b409@news.povray.org>, "Rune" <run### [at] inamecom>
> sample files generated errors
Yeah, I know...I was getting rather sick of the particle system patch,
and didn't have time to even test all the demo files. :-(
I'm writing new ones for the next version, those were more of feature
tests for the in-development versions.
> and the help files were in an unknown file format; I presume they are
> not for Windows.
They are plain text files, the problem is that Mac and Windows have
different line endings.
Well, you can find a decent text editor that can handle the different
line endings, or wait for the new version which will be in HTML to get
around this problem.
> sample animations?
I'll put some more up when I update my web page, sometime soon
(hopefully this weekend). The only images on my web site now are:
http://homepage.mac.com/chrishuff/images/particleFountain.jpg
http://homepage.mac.com/chrishuff/images/particleFountain2.jpg
(and just uploaded this one)
http://homepage.mac.com/chrishuff/images/Particles1.jpeg
Yeah, that's it. Titled "Absurd".
http://www.hot.ee/margusrt/eng/absurd3.html
Date: 23 Feb 2001 14:58:15
Message: <chrishuff-554873.14572023022001@news.povray.org>
In article <3a96b900@news.povray.org>, "Rune" <run### [at] inamecom>
If you have a large enough number of particles, they can appear to flow.
It works best when the particles are going downhill, though. And you
have to start them out close to the ground, and keep the bounce height
from decreasing too much, but if they bounce too high, they won't look
right.
I know...I once did a particle system with inter-particle forces in
plain POV-Script...I gave up after a couple multi-hour *parses*. The
thing was impossible to test, because it took so long to see any results.
I'll look around, maybe I still have that scene file around.
Not yet.
> If yes, how is it implemented?
I'll probably implement a kind of force based on object proximity...that
should allow flowing to work.
Date: 23 Feb 2001 16:21:28
Message: <3a96d458@news.povray.org>
> patch, and didn't have time to even test all the demo files. :-(
Sounds good.
> have different line endings.
That was not the problem, I just didn't know that they were plain text
files, since they had no extensions.
Thanks.
I've been looking at the particle_system patch documentation and I'd say
that my system is currently more flexible. However, when some of your
planned features are added, I think they will be much the same. And your
patch is much faster. But still the "user-interface" is very different and I
personally prefer mine, so I'll keep working on it... :)
Rune
Date: 23 Feb 2001 16:40:32
Message: <chrishuff-282ADA.16393823022001@news.povray.org>
In article <3a96d458@news.povray.org>, "Rune" <run### [at] inamecom>
Oh...file name extensions. Those silly things. ;-)
> say that my system is currently more flexible. However, when some of
> your planned features are added, I think they will be much the same.
In what ways do you think it could be improved? I'm just fishing for
ideas...
BTW, one of the changes I plan on doing is separate environment objects,
each with their own elasticity and other particle interaction
characteristics. You could have portions of what appears to be a smooth
wall but is really a pair of objects, one with more "slippery"
characteristics, the other with "sticky" characteristics, so particles
would stick to some parts of the wall but not others. You could spray
paint the wall and have an invisible message appear.
> And your patch is much faster. But still the "user-interface" is very
> different and I personally prefer mine, so I'll keep working on it...
I'll be interested in the results...
Date: 23 Feb 2001 17:57:03
Message: <3a96eabf@news.povray.org>
in the words of my significant other - looks like slime :)
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 27 Feb 2001 01:30:37
Message: <3a9b498d@news.povray.org>
As i understand it you could simulate some kind
> of flowing by making the particle lifetime high enough and using a high
> energy loss when bouncing.
I think this could work with collision detection.
Date: 27 Mar 2001 09:09:54
Message: <3ac09f32@news.povray.org>
Rune wrote in message <3a9581f3@news.povray.org>...
>Hope you like it!
Oh, yeah!
I got it looping on my other box right now.
You definitely have 'something' happening here.
I have to check your other posts and peoples responses, as
well as your web site.
So much to do and only a lifetime to do it.
Thanks,
Peter
