POV-Ray : Newsgroups : povray.binaries.animations : next asteroid/ring collide try [~108K mpg] Server Time
15 May 2026 08:17:15 EDT (-0400)
  next asteroid/ring collide try [~108K mpg] (Message 1 to 8 of 8)
Subject: next asteroid/ring collide try [~108K mpg]
Date: 23 Jan 2001 10:14:09
Message: <3a6d9fc1@news.povray.org>
Getting some interaction now using a media to form where the ring particles
interact with the asteroid.  Not great but it's an improvement.
This is the second part of 3 I have in mind for now, have yet to put all three
together.
Thinking I need to add some lights or radiosity to get the hot glow to
illuminate the surroundings.  Not looking forward to that.
Bob H.
omniVerse http://users.aol.com/persistenceofv/all.htm
Download 'ARC2.MPG' (80 KB)
Subject: Re: next asteroid/ring collide try [~108K mpg]
Date: 23 Jan 2001 10:30:51
Message: <3a6da3ab@news.povray.org>
the rock looks much better, dont like what you have done to the planet tho
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 23 Jan 2001 12:50:07
Message: <3A6DC44F.B70265ED@gmx.de>
> together.
I just thought, that the texture of the asteroid should change during
transit, because it would get more craters :-)
Concerning the ring, maybe some more variation in density and some less
sharp borders would be good.  It vould even be devided into several
smaller stripes.
Date: 23 Jan 2001 13:10:04
Message: <3a6dc8fc@news.povray.org>
news:3a6da3ab@news.povray.org...
No?  That's okay because like I had said before it will no doubt change again.
Bob H.
Subject: Re: next asteroid/ring collide try [~96K mpg]
Date: 23 Jan 2001 13:17:08
Message: <3a6dcaa4@news.povray.org>
news:3A6DC44F.B70265ED@gmx.de...
Ah yes, I haven't gotten to part 3 yet and that's where it will need that
happening.  I might not ever finish.
> smaller stripes.
It's all random right now, from closely spaced to wider spaced rings.  Colors
are random too but start from a medium gray.
I haven't figured a way of going about it to get gaps in the same density blend
map.  I'll post here with the part 1 animation so you can see the ring better
from a distance.  Small mpeg file.
Bob H.
Download 'ARC1.MPG' (70 KB)
Date: 23 Jan 2001 14:07:26
Message: <3A6DD66D.B1E7871D@gmx.de>
I know that feeling...
It looks really a bit to regular in both color and density.  I don't know
very much about media, so i can't help with that.  Some photos:
http://photojournal.jpl.nasa.gov/catalog/PIA01962.jpg
http://photojournal.jpl.nasa.gov/catalog/PIA02241.jpg
Date: 24 Jan 2001 16:58:54
Message: <3A6F5049.52647DDF@zerotensor.org>
i see that the planet is rotating.
I assume the ring rotates too,
so as the rock goes through the ring,
it should leave a wake or trail in the ring.
perhaps you could add a media element attached to the
asteroid that interacts with the media in the ring object
downstream to create the effect.  Is that how you made the
glow?  I really like how the leading edge glows bright.
I imagine a particle method would
work best for accurately simulating the ring,
 but that would take years to render.
Looks very slick anyhow.
_______________________
Eric Andersen
eri### [at] zerotensororg
http://zerotensor.org/
Date: 24 Jan 2001 19:54:27
Message: <3a6f7943@news.povray.org>
Thanks, yeah it is going to have some kind of downstream wake if I can manage
to add that.  CSG differencing away a hole didn't look good.
A close-up view of the interaction as it now is terrible too, you just don't
see it well in this yet.
It is a scaled up media-filled slice of the asteroid/ring intersection.  Pretty
simplistic except for the fact I have the scales, rotations and translations
all done first and yet the asteroid still passes through <0,0,0>.
One of those things that make me wish I could paint it in and not try to CSG my
way through.
Ring rotation is opposite direction of asteroid direction btw.
Bob H.
"Eric Andersen" <eri### [at] zerotensororg> wrote in message
news:3A6F5049.52647DDF@zerotensor.org...
> Eric Andersen
