POV-Ray : Newsgroups : povray.binaries.animations : Re: Torus Torture Server Time
15 May 2026 18:56:28 EDT (-0400)
  Re: Torus Torture (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Torus Torture
Date: 19 Jan 2001 14:25:25
Message: <3a6894a4@news.povray.org>
In povray.binaries.animations Rune <rune.johansen@iname.com> wrote:
> "Chris Huff" wrote:
>> "Rune" wrote:
>> > Also, my macro gives the user full control over the deformation.
>> > How would the user control the deformation in your patch? (I mean
>> > the deformations for meshes.)
>> Similar to the way patterns and warps are done: a set of predefined
>> deformations and maybe function-defined deformations. Maybe warps too.
> Predefined deformations does not give the user full control. Nor do warps.
> POV-Ray functions returns floats and not vectors, don't they?
> The only way the user can get full control, is by using functions where both
> input and output are vectors.
Well, they could always define a function for each of x,y,z.  Little messy,
though.
Geoff
Date: 19 Jan 2001 15:46:09
Message: <3a68a791@news.povray.org>
"Wlodzimierz ABX Skiba" wrote:
> Rune wrote:
> > a macro can be useful until the patch is ready.
> I agree with it, but ... patch is nearly ready :-)
But maybe your patch is better for some purposes while my macro is better
for others.
> can you twist plane{} ? :-)
Not an infinite plane obviously, since meshes can't be infinite.
> > It is also possible that the patch is not as flexible.
> > Will the user be able to use functions where both input
> > and output is vectors?
> in my specifications of possibilities, yes
> in first version, no
With my macros user-defined deformations are very easy simple.
This is a simple twist:
#macro deform_mezz (P) vrotate(P,120*x*P.x) #end
How would a user-defined twist look with your patch?
(I do *not* mean the build-in twist-deform. I mean user-defined function!)
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
Date: 19 Jan 2001 15:46:16
Message: <3a68a798@news.povray.org>
"Chris Huff" wrote:
> > Nor do warps.
> Yes, but it might be possible to combine three of them into a
> single function that returns a vector. This would be best with
> variables in functions, but would be quite useable otherwise.
> Or you could just use three separate functions...
Doesn't sound intuitive at all I think!
I prefer a user-defined twist to be as simple to make as this:
Rune
Date: 19 Jan 2001 15:58:48
Message: <chrishuff-EEDEF0.15595319012001@news.povray.org>
In article <3a68a798@news.povray.org>, "Rune" <run### [at] inamecom>
I don't see how it is any less intuitive than the < X, Y, Z> vector
syntax...the user would just be specifying expressions that would be
evaluated when the function is computed instead of at parse time. Or
were you talking about using three separate functions?
Using macros would be too slow...and I've tried to figure out how to do
it before, with no success. I think macros should remain parse-time, and
that functions should be extended instead.
Christopher James Huff
Date: 19 Jan 2001 18:25:37
Message: <3a68ccf1@news.povray.org>
> vector syntax...the user would just be specifying expressions
> that would be evaluated when the function is computed instead
> of at parse time.
But I don't really know how the <X,Y,Z> syntax would work.
What I would prefer is to deform a mesh just like I would deform a point.
Like this:
Translate by <1,2,3>: P+<1,2,3>
Scale by <1,2,3>: P*<1,2,3>
Rotate 55 degrees about A axis: vaxis_rotate(P,A,55)
To make more complicated deforms I can take advantage of #local or #declare:
#declare A = P*<1,2,1>;
#declare B = P+<2,1,1>;
vrotate(A,90*x*B.x)
I find that it couldn't be more simple and intuitive than this. Could a
deform function be made to work the same way?
The macro was not the important part.
Rune
Date: 19 Jan 2001 20:25:55
Message: <chrishuff-1E72A8.20265819012001@news.povray.org>
In article <3a68ccf1@news.povray.org>, "Rune" <run### [at] inamecom>
It would take the XYZ coordinates of a point and output new XYZ
coordinates...you could even have built-in "vector" functions like
vrotate and vaxis_rotate, though they would only return a component at a
time. (vrotate_x(px, py, pz, rx, ry, rz), vaxis_rotate_y(), etc...
> Like this:
> #declare:
> vrotate(A,90*x*B.x)
Not without a substantial amount of work...basically replicating the
functionality of isosurface functions for vectors and writing code to
parse stuff that looks like POV-Script on the fly. If this was easy or
even just a bit difficult, don't you think it would have been done
already for isosurface functions?
Well, it should be possible to make a version of functions that handles
only vectors, but it seems like an unnecessary inconsistency with the
float version, and you likely wouldn't be able to use the two together.
And if you really want to use a macro, you could always read the data
from the mesh, do what you want with it using a macro, and create a new
mesh with it. (Using the mesh data stuff Warp wrote.)
Maybe you could provide a sample of the syntax you would use?
Date: 20 Jan 2001 07:02:03
Message: <3a697e3b@news.povray.org>
"Chris Huff" wrote:
> they would only return a component at a time.
Ough!
> > deform a point. I find that it couldn't be more simple and
> > intuitive than this. Could a deform function be made to
> > work the same way?
> replicating the functionality of isosurface functions for
> vectors and writing code to parse stuff that looks like
> POV-Script on the fly. If this was easy or even just a
But isosurfaces and meshes are completely different things!
Isosurfaces are fields defined for every point in space. A surface is
created wherever the field equals a certain value. Meshes are completely
different. There's no field, there's just a bunch of points in space
connected by triangles.
For isosurfaces it makes sense to change the field values by using functions
that return floats.
For meshes it makes sense to directly move the vector points by using
functions that return vectors.
> handles only vectors, but it seems like an unnecessary
> inconsistency with the float version, and you likely
But it's two completely different things! It wouldn't make sense to make
them consistent or to use them together.
> the data from the mesh, do what you want with it using a
> macro, and create a new mesh with it.
Err Chris, that's what I'm already doing. This whole thread origins from my
message in povray.binaries.animations with an example of a mesh deformed by
a macro. But I was discussing with ABX if a patch could do it as easily and
flexibly (to the user) as a macro.
Seems that it can't...
Rune
Date: 20 Jan 2001 10:28:55
Message: <chrishuff-9F7523.10300020012001@news.povray.org>
In article <3a697e3b@news.povray.org>, "Rune" <run### [at] inamecom>
> Ough!
That was my solution for handling vectors in a float-based function...it
probably wouldn't be impossible to extend functions to handle vectors as
well.
> functions that return floats.
You have completely missed the point...
This has *nothing* to do with isosurfaces, it's about executing
user-written code multiple times at a later time, between parse and
render time or even at render time. With macros, you can't do that, and
functions are the only things that can do that (well, forget about
shaders for the moment, since they are specialized for color processing,
but they may also be a solution), so it makes sense to use them as an
example and a base for the vector stuff.
Since this specific application only needs to be done at parse time, it
should be possible to use macros (if you can figure out how, I attempted
this as part of my particle system patch but never figured it out), but
speed will suffer, and there are other applications of the same thing
that would need to be done at render-time.
Why not? Each component of a vector is a float, allowing the user to use
float functions in vector functions would be very powerful. And I don't
see a reason to make another, very different version of the syntax just
to support vector functions. They are *very* closely related, the only
difference is that one handles scalars and the other handles vectors.
Why do you think I mentioned it? ;-)
> This whole thread origins from my message in
> povray.binaries.animations with an example of a mesh deformed by a
> and flexibly (to the user) as a macro.
As flexibly? No...not without a lot of changes and additions. How easy
it would be would depend on your needs, a macro based solution will be
easy to modify to suit your needs but far slower.
Date: 22 Jan 2001 05:41:25
Message: <3a6c0e55@news.povray.org>
Rune wrote in message <3a697e3b@news.povray.org>...
It seems that it could...
It can't at current level of pov syntax but after some patches (my plans) it
could be done.
Did you carefully read proposition of my syntax ?
This is even better than macros becouse it can use default values of input
parameters.
ABX
Date: 22 Jan 2001 07:01:12
Message: <3a6c2108@news.povray.org>
Rune wrote in message <3a68a791@news.povray.org>...
I think such thing should be possible after my whole patching
#declare Twisting=function(speed=120,A[3]=<0,1,0>,P[3])
   { VRotate( P, VScale( speed, A )) }
where VRotate and VScale are previous defined or build-in functions, i.e.:
#declare VScale=function(a=1,V[3]=<1,2,3>)
    local V1[3]
    local V1[0]=a*V[0]
    local V1[1]=a*V[1]
    local V1[2]=a*V[2]
    V1
and with such definitions you can write what you want
twisting along y with default speed
  box { -1 1 deform { Twisting() } }
twisting along y with new speed
  box { -1 1 deform { Twisting(130) } }
twisting along x with new speed
  box { -1 1 deform { Twisting(100,x) } }
and remember that this deform both: geometry and texturing
is this simple enough ?
but I still prefer some simple build-in deformations
becouse they have not aproximated normals
and are calculated internally/faster
(not parsed during every calculation)
ABX
