POV-Ray : Newsgroups : povray.binaries.animations : Another guideline question Server Time
30 Mar 2026 15:31:24 EDT (-0400)
  Another guideline question (Message 1 to 10 of 11)
Subject: Another guideline question
Date: 9 Dec 2000 15:33:27
Message: <3a329717@news.povray.org>
Which format and codec should I use if I want a reasonable good
compression/quality and I want as many as possible to be able to see my
animations, just like that, without having to download a new codec?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 9)
/ Also visit http://www.povrayusers.org
Subject: Re: Another guideline question
Date: 9 Dec 2000 19:06:40
Message: <3A32C8E4.ADA7C068@onwijs.com>
It could depend on the type of animation (cartoony or not for instance).
As far as I know Cinepak is a not too obscure AVI- compression method and it
does give you the possibility of setting the compression. The latest Intel codec
was quite good, but I don't know how common that is.
I don't know much about MPEG, I often find the quality too poor.
Skol!
Remco
> Rune
Date: 10 Dec 2000 00:07:01
Message: <3A330F72.D4A53D34@ij.net>
	From some modest experimentation NOT EXHAUSTIVE I find MPEG-1 to be
about the size of the sum of the jpeg versions of the frames regardless
of the format created. I tested that by creating mpegs with the original
and the jpeg converted format. While not exhaustive that should address
the compression issue. I can not find any option in mpeg-1 to control
the compression but I make no claim to expertise in it.
	As to quality my unconfirmed opinion is:
	The way mpeg-1 creates interpolated frames suffers horribly when there
are screen-wide slight changes. It pixelates them almost. I posted a
couple such results here but not the stills for comparison. S-U-C-K-S
compared to the stills.
	However where the image changes rather little I would rate the results
outstanding.
The only thing Israelies understand is violence.
	-- The Iron Webmaster, 335
Date: 10 Dec 2000 05:53:05
Message: <3A33605E.646D06A8@worldonline.nl>
Try Quicktime because then you're able to reach PC and Mac users.
Rob.
> Rune
Date: 10 Dec 2000 06:23:16
Message: <3A336778.CA9367E6@onwijs.com>
Yuck! ;)
But seriously, Quicktime suffers from the same problems as other formats: the
versions. On top of that: I had to download the latest Quicktime player to view
a certain fragment and it did some less friendly things to my setup (suddenly
it's a plugin in Netscape for formats I had no problem with, to name an
example).
Remco
> Rob.
> > Rune
Date: 11 Dec 2000 02:03:25
Message: <3a347c3d@news.povray.org>
Matt Giwer wrote in message <3A330F72.D4A53D34@ij.net>...
From my rather exhaustive experiments, I have found that you can get a very
wide range of sizes for your output file.  I've gotten compression ranges
between 20:1 and 500:1 with different settings for the same animation.
Quality is in direct proportion to the compression ratio.
I recommend using the Berkley MPEG encoder.  It takes a bit of work to use,
but gives you the most control over the output.
Mark
"The derivative of sin(2x) is cos(2x)"  - Matt Giwer
"I never said that" - Matt Giwer
"I completely agree a flywheel can store a million times more energy if its
rotational velocity is measured in microradians instead of radians." - Matt
Giwer
Date: 11 Dec 2000 09:17:31
Message: <3A34E097.1F6D6BD1@my-dejanews.com>
To reach a wide audience, use MPG-1.
To get good compression, get a high-tech MPG encoder.
MainActor cost me I think $89US and makes MPG-1 as well as some higher
codecs if you want.
http://www.mainconcept.com/
Good side: It allows you to prescribe the exact number of kb/sec you want
in the final anim.
Bad side: It forces you to prescribe the exact number of kb/sec you want in
the final anim.
Thus with experimentation you can set it up to get just enough kb to get a
pretty video.
Date: 12 Dec 2000 23:36:29
Message: <3A36FCCB.60351F3B@ij.net>
	To take it one step further, jpeg compression varies by the variations
in the scene. If you do an animation with one little thing moving around
you get great compression. The more of the scene that is changing from
frame to frame the compression is much less.
	It is clearly not a one dimensional problem.
The difference between chads and chaos is od.
If it is digital it is mine.
If it is on magnetic media it is mine.
In fact, oddly, if I pay for it is it mine.
	-- The Iron Webmaster, 349
Date: 13 Dec 2000 22:02:27
Message: <3A383875.AE233FB4@yahoo.com>
> example).
It isn't available in Linux and is a closed source, which we should all
boycott...
I love Macintosh, but I hate closed source...  My opinion
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Date: 13 Dec 2000 22:04:15
Message: <3A3838E0.8D68EC72@yahoo.com>
Try Berkley's MPEG encoder
It costs Nothing and has the same good and bad sizes as this commercial one...
> codecs if you want.
> the final anim.
> pretty video.
