POV-Ray : Newsgroups : povray.binaries.animations : DivX Encoder? Server Time
3 Jul 2026 08:29:23 EDT (-0400)
  DivX Encoder? (Message 11 to 15 of 15)
Subject: Re: DivX Encoder?
Date: 31 Jul 2002 22:23:27
Message: <3D489D0C.4070603@faricy.net>
Bryan Valencia wrote:
 > WARNING: I downloaded a DIVX player and it put GATOR SPYWARE on my
 > machine.
I got the regular DivX stuff and I have no reason to believe it put
spyware on my machine.  DivX Pro does, but it says it does, so there's
really nothing to complain about.
___     ______________________________________________
  | \     |_         website: http://davidf.faricy.net/
  |_/avid |ontaine           email: <dav### [at] faricynet>
Date: 31 Jul 2002 22:37:58
Message: <3D48A073.9080001@faricy.net>
Well, I tried VideoMach, it seems like a great program, but I can only
use it for 30 days and then I have to buy it.  Might have another look
at VirtualDub, but it can't read my mpegs made by cmpeg or mpeg2encode.
As for the DivX codec itself, I was greatly disappointed by the quality
and size of the animations it produced, regardless of the settings,
especially compared with what cmpeg can output in plain mpeg-1.  I got
by far the best results with Indeo, but all the codecs seem to lack the
sort of options a program like cmpeg has, where it can make better
quality animations at the expense of processing time.  Even with DivX on
"slowest" encoding and 2 passes, Video Mach whipped through 160 frames
in a few seconds, and, not to my surprise, the animation was huge and
ugly.  I may just stick with cmpeg.
Date: 1 Aug 2002 01:42:34
Message: <3d48ca4a$1@news.povray.org>
news:3D4### [at] faricynet...
> Even with DivX on "slowest" encoding and 2 passes, Video Mach
> whipped through 160 frames in a few seconds, and, not to my surprise,
> the animation was huge and ugly.  I may just stick with cmpeg.
http://www.tmpgenc.net/e_main2.html with the plug-in for PNG is a nice
solution.  The plugin is in the p.b.u newsgroup  3a82f26c@news.povray.org
Date: 1 Aug 2002 10:53:39
Message: <3d494b73@news.povray.org>
You can only use it for non commercial use after the 30 days.
Date: 24 Sep 2002 12:48:36
Message: <3d909764@news.povray.org>
Or even easier, just load the first .bmp and VirtualDub will load in the
rest, set you frame-rate in Video options, select your encoding method
(1-pass quality based with quantizer set to 3.5 (95%) gives small and good
looking files (mostly, experiment with the divx settings to find the optimal
for your anim). Then just save as .avi!
"Hugo" <hua### [at] post3teledk> wrote in message
news:3d4821f5$1@news.povray.org...
> > Couldn't be easier. What I do is use Bink and Smacker
> Yes that's easy, but you can do it directly in Virtual Dub: Use the "logo"
> filter to add a full screen BMP logo, select no transparancy, and select
> "animation" with duration of 1 frame per BMP file.. Name the BMP files
like
> this:
> etc.. The important thing is just to use 4 digits at the end of the name..
> That's easy and you can output directly to Mpeg4.
> Regards,
> Hugo
