POV-Ray : Newsgroups : povray.binaries.animations : Wind Algorithm, Take 2 (MPEG, 192kb) Server Time
23 Apr 2026 00:23:58 EDT (-0400)
  Wind Algorithm, Take 2 (MPEG, 192kb) (Message 1 to 3 of 3)
Subject: Wind Algorithm, Take 2 (MPEG, 192kb)
Date: 4 Mar 2002 14:29:55
Message: <3C83CAF7.6CBC5FC6@gmx.de>
So, I've cleaned the code a little, using some suggestions
given earlier by Rune and Mark.
Particle start with a smooth-turbulenced initial direction,
but tend to move with the actual wind-direction (<1,0,0>)
after a given amount of time.
Result:
Particles spread out, at first smoothly, but it looks chaotic in
the end.
You recognize where particles begin to move with the wind,
as the expansion stops.
All in all, it just looks crappy. The algorithm isn't (in this system)
worth the effort. I could just randomly turbulence, or add
some random vector to be added to the position in the first
few seconds of a particle's lifetime, and it would
look the same. :-(
So I've decided to work on it so that it may be used to
create varying wind-direction and speed over time.
Sadly, non-I/O binds me to the issue that particles
may start with different initial settings, but when
you see a particle blown with wind-speeds of
5mph and a particle passing it with higher speed,
it would just look stupid.
So, finally, I decided to discard that idea. I'm pondering
a little about a different approach, but right now, I think
I'll just leave it.
It gave me some more ideas for an I/O system, as well
as some other nice stuff (for example leaves falling
to the ground tumbling), but we'll see.
Thanks for comments anyway!
Tim Nikias
Download 'smoke2.mpg' (193 KB)
Subject: Re: Wind Algorithm, Take 2 (MPEG, 192kb)
Date: 4 Mar 2002 18:39:56
Message: <3C8404FC.9984A1C7@yahoo.com.au>
This does look a bit odd.
> look the same. :-(
It might not be the best smoke effecct, but I still think that if you put a good
texture on those spheres that made it _look_ like smoke (esp. fading with time), and
shot them out the back of the rocket (not stationary as you have done here), alot of
the problems would be less noticeable. As with most computer generated graphics, it
doesn't have to be a rigorous simulation of smoke, it just has to _look_ like smoke.
Why would it look stupid? This happens in real life sometimes.
Take a look at my reply to your first smoke anim too. I have posted a v. short anim of
my bozo technique you might want to look at.
MJL
text{ttf"timrom.ttf"concat(#local O=1;#while(O<7)chr(val(substr(concat(#local Q=
1;#while(Q<7)str(asc(substr("???<?>",Q,1))-56,0,0),#local Q=Q+1;#end""),O,2))),#
local O=O+2;#end"").1,0pigment{rgb 9}translate-<1,.3,-2>} // MJL
Date: 5 Mar 2002 00:53:15
Message: <3C845D63.2446BD96@gmx.de>
Well, okay, I won't drop it. I'll work on it a little
more and post a fancy animation the next time, and
perhaps then everything will be fine. At least it
will _look_ fine.
Thanks.
Tim Nikias
