POV-Ray : Newsgroups : povray.binaries.animations : Re: Improved and final goo (802kb file) Server Time
20 Jul 2025 13:45:45 EDT (-0400)
  Re: Improved and final goo (802kb file) (Message 1 to 10 of 11)
Subject: Re: Improved and final goo (802kb file)
Date: 12 Dec 2001 00:14:10
Message: <3C16E741.A13DD1F1@gmx.de>
I think it looks really good, with that sticking together
and splatternig apart going on. Did a good job there, and
looks much better than the first post (which was a little
distracting, with all those cones showing the direction...)
Tim
Date: 12 Dec 2001 06:41:36
Message: <3c174270@news.povray.org>
"Tim Nikias" <Tim### [at] gmxde> wrote in message
news:3C16E741.A13DD1F1@gmx.de...
I liked the cones :) - they should be a feature in every particle system
PGP Public Key
Message: <3c174270$2@news.povray.org>
>     This is my final attempt , partly because of the outrageous render
time, and
> partly because I want to try some new stuff.. I think it is an improvement
on the
> last one. Now the particles splash when they hit the ground plane, which I
think
> is a nice effect. The cohesive force used is similar to the last
animation; same
> attractivity, but (much) more repulsion. This means the particles compress
less,
> but the parse time has been increased by a factor of five (five
itterations per
> frame instead of one). This is to prevent the whole system practically
exploding
> when particles come too close to one another.
looks great!! What was the render time, and what cpu have you? - i am sure
someone will be very pleased to render a nice big one for you in exchange
for getting to peek at your code :)
PGP Public Key
Date: 12 Dec 2001 10:20:47
Message: <3C17756E.E1D97412@gmx.de>
That's not too difficult to implement, as I would guess doing something like
cone{Position,Radius Position+Direction*Velocity,0}
isn't that difficult to smuggle into the code somewhere...
Tim
Date: 12 Dec 2001 11:50:33
Message: <3c178ad9$1@news.povray.org>
It looks like 'purple squishy stuff' alright.
You could show it flowing into a cup at the 'quick E mart' <G>
                  == John ==
"Mark James Lewin" <m_j### [at] yahoocomau> wrote in message
news:3C16977B.565370B7@yahoo.com.au...
time, and
on the
think
animation; same
less,
itterations per
exploding
> Comments, criticisms, suggestions always welcome.
> MJL
> light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light
x,z,5,5}#macro A
> (H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local
V=asc(substr(B,I,1
> ))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red
1}rotate-<90,R>translate
> -T}#end
A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
> 25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}}
// MJL
Date: 12 Dec 2001 16:09:12
Message: <3C17C3BD.5FAB96C4@yahoo.com.au>
Thank you. In defense of the cones, they can help me spot problems, but yes,
blobs look much better.
MJL
> Tim
light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light x,z,5,5}#macro A
(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local V=asc(substr(B,I,1
))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red 1}rotate-<90,R>translate
-T}#end A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}}   // MJL
Date: 12 Dec 2001 16:22:18
Message: <3C17C6CF.7A723FA9@yahoo.com.au>
Thanks! The render time was (gulp) about 4 days, admittedly done mostly with low
priority on a 233MHz machine. I have an 800MHz machine sitting idle at the
moment, but it won't be for long...
My code is nasty and inefficient, and is getting an overhaul over Christmas.
Perhaps I'll get a mammoth scene together during that time, and be would be most
grateful for any offers to speed up the render if need be :-)
MJL
Date: 12 Dec 2001 16:25:21
Message: <3C17C786.EA735CB3@yahoo.com.au>
Yes, very easy indeed. My system was designed to be flexible in this regard. The
user (ie me :-) gets given particle position and velocity. It's then up to them
to do what they want with it. I have a few standard display options at the
moment, and just add or modify them as I need.
MJL
> Tim
Date: 12 Dec 2001 16:27:36
Message: <3C17C80D.FDEAAB8@yahoo.com.au>
Thanks. Flowing into something is a natural progression for the system. I don't
like the thought of the render time though.
MJL
Date: 12 Dec 2001 22:00:46
Message: <3C181610.33C1239F@yahoo.com.au>
or my particles are... I found one rogue particle that was hell bent on finding its
way through that ground plane, and slowing the whole render down as it went.
Deleting that one particle has increased the speed of the render by at least a
factor of three for the last couple of frames.
MJL
