POV-Ray : Newsgroups : povray.binaries.animations : ik walk Server Time
3 Jul 2026 20:59:06 EDT (-0400)
  ik walk (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: ik walk
Date: 30 May 2001 14:25:15
Message: <3b153b0b@news.povray.org>
Impressive walk cycle!
I'm working with IK myself and I'm always looking for inspiration.
I'd appreciate if you could explain how you move the feet around. Do you use
splines for the position of the feet? And how do you control how much the
feet point upwards/downwards - another spline?
And what do you mean when you say that the toe detects the ground? Do you
use trace?
If you're interested, you can see my own experiments on this page:
http://rsj.mobilixnet.dk/3d/anims/anims.html
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated May 10)
Subject: Re: whoops
Date: 30 May 2001 17:13:47
Message: <3b15628b@news.povray.org>
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3b14c225@news.povray.org...
> "Dearmad" <dea### [at] qwestnet> wrote in message
> news:3B14B9B0.CF5E42FF@qwest.net...
> > i'm cursed... QT4 on my machine is giving me a black
> > screen.  grrr. :(
> Windows Media player says it doesn't have the codec. maybe I should
reinstall it
> or something.
Same here and I just finished installing every codex I could get my mits on
:( It wants to reconnect for the codex, too (after I'd just disconnected,
damnit)
Date: 30 May 2001 17:42:54
Message: <3B156928.A9111869@chorus.net>
> use trace?
Using the core of your ikleg macro that you posted for me a while ago, I just
added in support for a foot that is always perpendicular to the vector from the
ankle to the hip.  Next, I added in a rotation that rotates the foot before it
is transformed.  I just used the vectors from the matrix transformation to have
it figure out a toe point and basically raise the foot if the y-coord is below
a defined floor level.  As for the motion, I just used my own macro for
motion.  I'll post it in the binaries.scene-files group.
 - Rico
Subject: Re: whoops
Date: 30 May 2001 21:57:24
Message: <3b15a504$1@news.povray.org>
You gave your first one an ".mpg" extension, it should be ".mov" other than
that they both work fine in QT5 here.
Just to clarify, an MPG or MPEG is a type of file completely different than
QT or MOV; you created a quicktime file which uses a Motion JPEG codec,
which is similar in concept to MPEG, but a completely different type of
file.
"Reusser" <reu### [at] chorusnet> wrote in message
news:3B146564.B06FAAFA@chorus.net...
> Well shoot.  Here's one last effort.  I have a mac and I just encoded it
in the
> mpeg a and b formats with quicktime, so if anyone with a mac knows how to
save
> these movies in a format that works, PLEASE reply.
Date: 31 May 2001 06:31:45
Message: <3b161d91@news.povray.org>
"Reusser" wrote:
> As for the motion, I just used my own macro for motion.
Thanks!
Your motion macros remind me of those made by Chris Colefax. Do you know if
there are any major differences?
Rune
Date: 31 May 2001 17:22:35
Message: <3B16B5BF.D199292E@chorus.net>
> there are any major differences.
A while ago, I did download his macro, but I needed it to do a couple of other
things for an animation I was working on, so I just started from the ground up
and wrote a new macro that would do a pretty similar thing, just in a
different way.  I always hate using other people's macros when you don't
really understand exactly what is going on.  Now after downloading his macro
again, I read the copyright notice in the documentation and feel kinda bad.
Is there a way I can have my post removed from the scene-files group to comply
with his copyright?
 -Rico
Date: 31 May 2001 18:30:11
Message: <3b16c5f3@news.povray.org>
"Reusser" wrote:
> I just started from the ground up and wrote a new
> in a different way.
That's great! You always learn a lot that way.
> Now after downloading his macro again, I read the
> kinda bad.
You shouldn't! You can't copyright a technique or a concept. You can only
copyright so-called "intellectual property". It means that you may not copy
Chris Colefax's files or parts of them without his permission, but if you've
created your own macros from scratch, then they're your own completely and
you have the copyright.
BTW, you have copyright of your intellectual property no matter if you write
a copyright notice or not. The notice just makes it clear for others.
> the scene-files group to comply with his copyright?
No need to. :)
Rune
Date: 31 May 2001 18:42:57
Message: <3B16C869.B6911E8C@chorus.net>
Rune wrote:
> No need to. :)
Thanks.  I feel much better now.  In addition, I noticed that the hips were
swaying the wrong way, so I just switched the sway to a negative value and
added in a checkered floor (shudder) for reference.  Hope this looks more
realistic.
 - Rico
Download 'ikdemo3.mov' (187 KB)
Date: 31 May 2001 19:14:56
Message: <3b16d070@news.povray.org>
"Reusser" wrote:
> I noticed that the hips were swaying the wrong way,
> Hope this looks more realistic.
Sure does! :)
I just wish I could get my QuickTime player to loop... :(
Rune
Date: 31 May 2001 20:21:29
Message: <3B16DFD1.F107426D@chorus.net>
Looking back at the old posts, I noticed Al, the walk/running alien.  I
saw your comment about IK not being very forgiving to extended legs and
I know exactly what you're talking about.  In the file I posted, I
altered the knee macro so that it would point the limb in the direction
of the ankle if the points are too far apart.  I also added in a feature
so you can set a certain amount of resistance so the knees don't snap
when they fully extend.  In my code, I set it so the limb would show the
resistance between the fully extended joint +/- the added distance of
the cushion variable.
 -Rico
