POV-Ray : Newsgroups : povray.binaries.animations : Re: Animated paperplane v0.1 - paperplane2.avi (1/1) Server Time
3 Jul 2026 22:31:56 EDT (-0400)
  Re: Animated paperplane v0.1 - paperplane2.avi (1/1) (Message 11 to 16 of 16)
Subject: Re: Animated paperplane v0.1 -- 3 attachments (65KBU)
Date: 27 Feb 2001 18:09:23
Message: <3A9C3389.D6DF4BE7@xs4all.nl>
Nikodemus Siivola wrote:
> Remco de Korte <rem### [at] xs4allnl> wrote in <3A9AFF6D.BC7DD671@xs4all.nl>:
> >I did a similar thing some time ago.
> >I've attached some small examples.
> >If the codec is a problem I could
> >post the larger (file) versions .
> Dunno if it is the codec or my computer, but unfortunately I was unable to
> view these...
I have already posted an mpeg version.
I didn't really remember what codec I used.
I created the AVI with Fast Movie Processor
and I just found it also supports the (a?)
MPEG4-codec. It could just be I used this,
but FMP gave the file an AVI extension just
as well. Perhaps you can view the files if
you change the extension?
> >Since I needed to have images on both
> >sides I couldn't use a mesh (or at
> I think that with MegaPOV you could, since all the triangles should have a
> normal vector - and therefore you could use the inside texture thingie. I
> think. Haven't tried.
Me neither. At the time I made this I didn't
have MegaPov yet.
> Actually, it could possibly be done with meshes even in normal POV-Ray, but
> it would have been a bit messy: You can apply textures to individual
> triangles, just make a "hollow" paper, where the top and bottom surfaces
> meet only at folding points, and are something like 0.000001 apart at
> maximum.
The problem with this approach is that you can
have folds crossing each other so it would be
rather difficult to calculate the triangles
(at least to me).
> >thin box with imagemaps, cutting and
> >folding. This is a recursive process
> >(isn't it?) and it took ages to render.
> Darn I hope I could see this. Before I decided to go the mesh-route I was
> considering something similar, along with a plenty of other options. How
> did you handle the points where the paper is folded several times over the
> same spot?
That's the problem. What I did was a more or
less recursive process. You start out with a
thin box, cut it in half and fold them on top.
Then you take this result, cut it in two parts
and fold those together, etc. Obviously with
only a few folds this will result in a whole
clutter of CSG for POV-Ray to wade through.
Anyway, I did get the imagemaps right and that
was the whole point.
There is something else, which I saw you also
handled really well: the thickness of the
paper and the room between folds. I don't know
how you did it but it took me quite some
trial and error to get it right.
> Yours,
>   -- Nikodemus
Kind regards,
Remco
http://www.onwijs.com/
Date: 27 Feb 2001 21:21:39
Message: <chrishuff-024311.21202927022001@news.povray.org>
In article <Xns90567D065894tsiivolacchutfi@204.213.191.228>,
> have a normal vector - and therefore you could use the inside texture
> thingie. I think. Haven't tried.
The interior_texture feature should work fine with triangles, the side
that is "outside" or "up" is determined by the order of the vertices. As
I recall, "up" is the direction from which the points wind clockwise.
Christopher James Huff
Date: 28 Feb 2001 06:21:32
Message: <Xns9056880288393tsiivolacchutfi@204.213.191.228>
I cannot really claim to know this stuff - like I mentioned, the paperplane
was my first animation (discounting the tutorial) - but try VideoMach. It
is a successor of the Fast Movie Processor, and it supports .png as input
format, and mpeg1 (among others) as output. And most importantly for me
it's easy to use...
>> POV-Ray, but it would have been a bit messy: You can apply textures to
>> individual triangles, just make a "hollow" paper, where the top and
>> bottom surfaces meet only at folding points, and are something like
>> 0.000001 apart at maximum.
>(at least to me).
What I did was first fold the a real paperplane, unfold it and draw the
creases on graph paper. Then it was time for some head-banging and
trigonometry to find out the points where the creases cross each other or
the edge of the paper. This process was much aided by rendering each
relevant set of triangles (one set per area delimeted by creases) in a
different color while having the "paper" in it's unfolded state. Easy
visual verification for having the points right.
Thanks! It wasn't the hard part, really. Once I had the points (vectors)
declared I used a simple macro to rotate the relevant points around the
fold-lines. The hard part was the topology of the paper: which fold folds
when, where and around what.
Also, I cheated:
A) only the "right" side of the plane is really modelled, the left side is
just a copy of the right scaled <-1, 1, 1>. B) a couple of points along the
center-line are checked to see if they have crossed to the wrong side. If
they have, they are returned to the center line. If I didn't do this the
paper would "tear" on a couple of points.
Yours,
 -- Nikodemus
Date: 28 Feb 2001 06:38:59
Message: <Xns90568AF81672Ctsiivolacchutfi@204.213.191.226>
Thanks! Will have to try.
 - Nikodemus
Date: 28 Feb 2001 06:47:24
Message: <Xns90568C6598F3Btsiivolacchutfi@204.213.191.226>
<3A9C3389.D6DF4BE7@xs4all.nl>:
Was finally able to view it: very nice! I can see why you wanted it done
with pigments...
 - Nikodemus
Date: 28 Feb 2001 09:09:20
Message: <3A9D0675.BC87BFAE@xs4all.nl>
> Also, I cheated:
> Yours,
>  -- Nikodemus
Cheater! 8)
It's a good trick, though. I was glad I figured out how to do it the hard way
and after that I could leave the rest up to my system (which needed a couple of
days to render the whole bunch).
BTW the method I used wasn't really very hard once I figured out how to do it.
Just find the line on which to fold, cut the model and rotate the parts around
this line. I also figured out how to more or less automate the correction for
the thickness of the paper. It's the long render times that were a problem
during the tests.
Remco
