POV-Ray : Newsgroups : povray.binaries.animations : +J and -J Server Time
22 Jul 2025 23:43:20 EDT (-0400)
  +J and -J (Message 1 to 6 of 6)
Subject: +J and -J
Date: 21 Dec 2000 01:10:59
Message: <3A419EF6.9C5AEF33@ij.net>
For animation with 3.1g an .ini setting of +J5.5 results in the
expected supersampling of 5.5 in the parsing report. So does -J5.5. Only
-J by itself results in 1.0.
	I have yet to test if this is an artifact of the parsing report or it
is in fact rendered with 5.5 wheter plus or minus.
Any explanation differing from the official government
explanation is likely true.
	-- The Iron Webmaster, 112
Subject: Re: +J and -J
Date: 21 Dec 2000 14:46:24
Message: <3a425e10@news.povray.org>
"Matt Giwer" <jul### [at] ijnet> wrote in message
news:3A419EF6.9C5AEF33@ij.net...
I seem to remember being confused by this before.
 When rendering an anim, it's best (I think) to turn jitter off. I used -j,
but jitter remained at 1.0. I think I managed to turn off jitter by using
jitter=off in my ini file.
Andy Cocker
Date: 21 Dec 2000 15:59:29
Message: <3a426f31@news.povray.org>
used -j,
I use +J0.00
Date: 21 Dec 2000 16:42:00
Message: <pq834t475nkq36i3m64pl0855u95ajq8mf@4ax.com>
POV doesn't use jittering when the value after +J is non-positive.
However POV still parses and remembers that value and then reports it.
Try -J5.5 +J and see if it makes a difference with -J5.5 and +J on
their own.
Peter Popov ICQ : 15002700
Subject: Thanks +J and -J
Date: 21 Dec 2000 22:35:34
Message: <3A42CC05.221FA759@ij.net>
	Thanks to all on this. It looks like I have to test this but the
consensus appears to be -J5.5 == -J regardless of what is reported. When
I get to it I will post.
There are millions of species. Taste before you exterminate.
	-- The Iron Webmaster, 69
Subject: Re: Thanks +J and -J
Date: 25 Dec 2000 02:42:44
Message: <3a46fa74@news.povray.org>
I always have to put +j0.0 in the command line to be sure there isn't any
jitter used.  Seems it never works in the ini when I try it there, or didn't
before or something.
-j0.0 should work okay too but I think it didn't if iirc.  That would be like
saying turn jitter off then use jitter = 0.0 next time according to the help
file.  Jitter isn't the easiest thing to check for correctness, would have to
be good test conditions.
Bob H.
Subject: Tested!
Date: 25 Dec 2000 04:10:42
Message: <3A470F11.6D820ACB@ij.net>
	I have now tested it. The visual difference may be there but not
noticable by me. Therefore -Jx.x is the same as -J to the limits of my
visual abilith and my screen resolution.
Pat Buchanan or the American Empire of Earth.
The choice was yours.
	-- The Iron Webmaster, 43
