this little animation is not meant to be artistic in any way. it is a
test for my tracking method. A while back in p.a-u I asked about the
matrix transform. I think I have gotten a little undestanding of it.
Basically, in this scene, a turret is placed at a location determined
via the trace() command. the gun the tracks the flying yellow ball. the
gun barrel and the turret are seperate objects and are controlled
separately.
I plan to make this a real scene, so stay tuned.... :-)
-paul
Paul Daniel Jones
120 Chandlee Laboratory
Penn State University
814-865-2090
pdj### [at] psuedu
http://research.chem.psu.edu/glassgrp/paul
Download 'out.avi.dat' (594 KB)
p.s.
sorry the file is a bit big, I have not gotten proficient with mpeg
compression yet.... every time I make an mpeg, it looks horrible.. !!
-paul
The turret looks somewhat like the Stumpy tank from Total Annihilation
A little on the fast side, but very neat
"Paul Daniel Jones" wrote
> p.s.
Still looks impressive, either way :)
I can't see it on my mac. Apparently I don't have the codec. mpeg is
horrible, yes, but at least I'd be able to view it. Most AVI's play
fine on my machine, but not this one--which codec are you using?
Paul Daniel Jones wrote:
> p.s.
> -paul
In article <39DF882A.323DBC99@zerotensor.org>, eri### [at] zerotensororg
Hmm, it worked fine on mine...what OS/QuickTime version do you have? I
have OS 9.0.4...
Christopher James Huff
Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
i must apologize for the trouble, I really don't know much about the
different formats, I just make crunch the images into a format that looks
good and work on my PC. Can someone suggest a good program to make good
mpegs? right now I am using bmp2avi... which I don't really like too much.
it is tough to get feed back if no one can see you work... ;-)
-paul
> > p.s.
> > -paul
Paul Daniel Jones
814-865-2090
pdj### [at] psuedu
in povray.binaries.animations, Paul Daniel Jones says...
> -paul
Have you tried CMPEG? If you find the attached mpg acceptable: it was
done with it. Only thing is you have to start with uncompressed TGA...
Hope this helps.
Regards, Sander
Download 'Out4.mpg' (105 KB)
Subject: Re: auto-tracking [594 Kb] - Out4.mpg [1/1]
Date: 10 Oct 2000 08:24:35
Message: <39E30AC6.B398279D@psu.edu>
Hey Thanks a lot... that looked really good.
-paul
> > -paul
> Hope this helps.
> Regards, Sander
> Out4.mpg Type: Mpg File (application/x-pn-mpg)
> Encoding: x-uuencode
Paul Daniel Jones
814-865-2090
pdj### [at] psuedu
> have OS 9.0.4...
I'm running Quicktime 4.1.2 on OS 9.0.4. Perhaps some sort of network
error or the like. No matter, Sander's mpeg-ed version played just
fine. (Thanks, Sander).
-Eric
