POV-Ray : Newsgroups : povray.binaries.animations : Proximity Man (430 kbbu) Server Time
15 May 2026 11:21:53 EDT (-0400)
  Proximity Man (430 kbbu) (Message 1 to 10 of 13)
Subject: Proximity Man (430 kbbu)
Date: 7 Sep 2000 17:53:32
Message: <39b80e5c@news.povray.org>
I applied the proximity texture to a box as my blob man walked through
it.  Not quite as cool as I expected....
Render time: 43 hours.  If I ever did this again, I would use a
combination of object and pigment patterns, as this is apparently only
showing proximity to a SURFACE of the object: I expected a "0" value for
all spaces inside the object....
Download 'proximity05.mpg' (430 KB)
Subject: Re: Proximity Man (430 kbbu)
Date: 7 Sep 2000 18:08:27
Message: <39B811D7.1C7E2EB8@spiritone.com>
Looks good, though. Like he's walking through a heat sensor.
>    proximity05.mpg    Type: WMPLAYER File (video/mpeg)
>                   Encoding: base64
eng### [at] spiritonecom
Date: 7 Sep 2000 18:55:25
Message: <chrishuff-E738A5.17571007092000@news.povray.org>
In article <39b80e5c@news.povray.org>, "Greg M. Johnson"
You didn't read the documentation. :-)
sides INT_SIDE
Use this keyword to decide which sides of the object to calculate the
pattern on.
0 Only the points inside the object are calculated.
1 Only the points outside the object are calculated.
2 All points are calculated.
I'm not surprised at the speed, though...didn't you try the blob pattern?
Christopher James Huff
Date: 8 Sep 2000 05:29:02
Message: <39b8b15e@news.povray.org>
READY-BREK !!!
Date: 8 Sep 2000 08:18:02
Message: <39B8D7C4.E782A159@my-dejanews.com>
If this were a compliment or a teasing pun, it went over my head...
"Rick [Kitty5]" wrote:
> READY-BREK !!!
> Rick
Date: 8 Sep 2000 08:25:50
Message: <39B8D992.C5E1300B@my-dejanews.com>
> sides INT_SIDE
> pattern on.
So how do I make it the regular kind of gradient for points outside the
surface, but 0 everywhere inside?  I don't remember what I used and don't see
an answer in what you copied.  I'm thinking I have to do this with a map first
on the object pattern...
My blob guy has about 200 components and my walking INC is so complicated that
I often forget how to use it if I let it sit for a week. I don't want to try
to import it into another pigment with its own complicated syntax.   I started
out trying to get a kind of shroud of turin effect with the face because it is
so detailed.
Date: 8 Sep 2000 11:45:25
Message: <39B90997.A192665F@spiritone.com>
I was reminded of the shape of an Football player, and this comment
reminds me of a Football huddle... (That's American Football, BTW)
Josh
> > READY-BREK !!!
> > Rick
Date: 8 Sep 2000 15:19:30
Message: <39b93bc2@news.povray.org>
Hi Greg.  Ready-Brek is a nice sort of porridgy, (oats), breakfast, (just
add hot milk)!  But the advert that goes with it on UK TV, features a young
lad and his sister, IIRC, that go to school on a cold morning, with a nice
warm *glow* around them after having their READY-BREK.  It does remind me of
that also :o)
     Nice ani, btw.   ~Steve~
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:39B8D7C4.E782A159@my-dejanews.com...
> > READY-BREK !!!
> > Rick
Date: 8 Sep 2000 17:11:47
Message: <MPG.14235dc3a0315ed29897c8@news.povray.org>
On Fri, 8 Sep 2000 20:16:57 +0100, 25ct wrote...
> that also :o)
Oh, and it might be a UK only reference :)
But I like the pseudo false colour thermograph effect.
Bye for now,
     Jamie.
Date: 8 Sep 2000 17:22:14
Message: <chrishuff-9AAB22.16240108092000@news.povray.org>
In article <39B8D992.C5E1300B@my-dejanews.com>,
> the surface, but 0 everywhere inside?  I don't remember what I used
> and don't see an answer in what you copied.  I'm thinking I have to
> do this with a map first on the object pattern...
Just add "sides 1" in the proximity pattern block. The object pattern is
not necessary, and would be a waste of time(both coding and rendering),
since the same calculations are already done in the proximity pattern.
> > pattern?
> complicated that I often forget how to use it if I let it sit for a
> week. I don't want to try to import it into another pigment with its
> own complicated syntax.   I started out trying to get a kind of
> shroud of turin effect with the face because it is so detailed.
You don't have to rewrite anything...you do know that with MegaPOVPlus,
you can use blob objects to control the blob pattern, don't you?
Of course, in MegaPOVPlus, you would *have* to use the blob pattern,
since the proximity pattern isn't in working order right now...
