POV-Ray : Newsgroups : povray.binaries.animations : auto-tracking [594 Kb] Server Time
20 Jun 2026 04:32:10 EDT (-0400)
  auto-tracking [594 Kb] (Message 1 to 10 of 10)
Subject: auto-tracking [594 Kb]
Date: 4 Oct 2000 08:24:50
Message: <39DB2206.198A1493@psu.edu>
this little animation is not meant to be artistic in any way. it is a
test for my tracking method. A while back in p.a-u I asked about the
matrix transform. I think I have gotten a little undestanding of it.
Basically, in this scene, a turret is placed at a location determined
via the trace() command. the gun the tracks the flying yellow ball. the
gun barrel and the turret are seperate objects and are controlled
separately.
I plan to make this a real scene, so stay tuned....   :-)
-paul
Paul Daniel Jones
120 Chandlee Laboratory
Penn State University
814-865-2090
pdj### [at] psuedu
http://research.chem.psu.edu/glassgrp/paul
Download 'out.avi.dat' (594 KB)
Subject: Re: auto-tracking [594 Kb]
Date: 4 Oct 2000 08:26:33
Message: <39DB2273.46835F12@psu.edu>
p.s.
sorry the file is a bit big, I have not gotten proficient with mpeg
compression yet.... every time I make an mpeg, it looks horrible.. !!
-paul
Date: 4 Oct 2000 16:07:41
Message: <39db8e0d@news.povray.org>
The turret looks somewhat like the Stumpy tank from Total Annihilation
A little on the fast side, but very neat
Date: 4 Oct 2000 17:11:57
Message: <39db9d1d@news.povray.org>
"Paul Daniel Jones" wrote
> p.s.
Still looks impressive, either way :)
Date: 7 Oct 2000 16:34:08
Message: <39DF882A.323DBC99@zerotensor.org>
I can't see it on my mac.  Apparently I don't have the codec.  mpeg is
horrible, yes, but at least I'd be able to view it.  Most AVI's play
fine on my machine, but not this one--which codec are you using?
Paul Daniel Jones wrote:
> p.s.
> -paul
Date: 8 Oct 2000 17:10:10
Message: <chrishuff-AD3206.16123908102000@news.povray.org>
In article <39DF882A.323DBC99@zerotensor.org>, eri### [at] zerotensororg
Hmm, it worked fine on mine...what OS/QuickTime version do you have? I
have OS 9.0.4...
Christopher James Huff
Date: 9 Oct 2000 08:52:30
Message: <39E1BFCA.67E2374@psu.edu>
i must apologize for the trouble, I really don't know much about the
different formats, I just make crunch the images into a format that looks
good and work on my PC. Can someone suggest a good program to make good
mpegs? right now I am using bmp2avi... which I don't really like too much.
it is tough to get feed back if no one can see you work... ;-)
-paul
> > p.s.
> > -paul
Paul Daniel Jones
814-865-2090
pdj### [at] psuedu
Subject: Re: auto-tracking [594 Kb] - Out4.mpg [1/1]
Date: 9 Oct 2000 16:36:13
Message: <MPG.144c4aa34a33431d98969a@news.povray.org>
in povray.binaries.animations, Paul Daniel Jones says...
> -paul
Have you tried CMPEG? If you find the attached mpg acceptable: it was
done with it. Only thing is you have to start with uncompressed TGA...
Hope this helps.
Regards,  Sander
Download 'Out4.mpg' (105 KB)
Date: 10 Oct 2000 08:24:35
Message: <39E30AC6.B398279D@psu.edu>
Hey Thanks a lot... that looked really good.
-paul
> > -paul
> Hope this helps.
> Regards,  Sander
>    Out4.mpg    Type: Mpg File (application/x-pn-mpg)
>            Encoding: x-uuencode
Paul Daniel Jones
814-865-2090
pdj### [at] psuedu
Date: 10 Oct 2000 16:37:44
Message: <39E37D87.1899BABA@zerotensor.org>
> have OS 9.0.4...
I'm running Quicktime 4.1.2 on OS 9.0.4.  Perhaps some sort of network
error or the like.  No matter, Sander's mpeg-ed version played just
fine.  (Thanks, Sander).
-Eric
