POV-Ray : Newsgroups : povray.binaries.animations : Re: Glowing Space Explosion Server Time
15 May 2026 17:43:18 EDT (-0400)
  Re: Glowing Space Explosion (Message 1 to 1 of 1)
Subject: Re: Glowing Space Explosion
Date: 7 Sep 2000 16:51:46
Message: <39B7FF77.DC9EE85E@pacbell.net>
Rune wrote:
> And there's also some major bugs in the official version that has been fixed
> in MegaPOV...
<follow-ups to povray.general>
Major bugs such as what ?
Date: 7 Sep 2000 16:56:27
Message: <39b800fb@news.povray.org>
"Ken" wrote:
> > version that has been fixed in MegaPOV...
Such as the normal bugs.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated July 23)
/ Also visit http://www.povrayusers.org
Date: 7 Sep 2000 17:01:46
Message: <39B801D1.A16D8FF@pacbell.net>
I never really accepted that those were bugs. I think of the
changes that Nathan made as design changes since they completely
broke backward compatibility with past versions of the program.
Date: 7 Sep 2000 18:07:36
Message: <39b811a8@news.povray.org>
I consider it bugs indeed. I think I was one of the first to complain about
the strange way the normals worked. When scaling objects, the normals
changed. For example, in the scenes where I used Blob_Man I had to scale my
whole scene to fit Blob_Man rather than just scaling Blob_Man, because if I
scaled Blob_Man his skin and clothed looked all wrong. That's very annoying,
very unintuitive, and very inconsistent, and therefore I consider it a bug.
I don't think the broken backward compatibility makes it less a bug - on the
contrary. Since the bug affected practically all scenes using normals I
consider it a *major* bug. The bug was so big that the bug-fix had to brake
backward compatibility.
Rune
Date: 7 Sep 2000 19:16:42
Message: <39B82171.9EE6DD0C@pacbell.net>
The feature worked exactly as it was designed therefore it was
not a bug. Just because a feature didn't work as YOU wanted it
to doesn't mean it was a bug.
Ken Tyler
Date: 8 Sep 2000 06:04:36
Message: <39b8b9b4@news.povray.org>
But the POV-Team says it is a bug.
I quote:
YES - These will be in POV 3.5
Normal bug fix (and all related stuff)"
Can you show me a quote that proves the opposite?
Rune
Date: 8 Sep 2000 06:42:39
Message: <39b8c29f@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: I never really accepted that those were bugs. I think of the
: changes that Nathan made as design changes since they completely
: broke backward compatibility with past versions of the program.
  Usually bug fixes break backwards compatibility if the older scenes use
the buggy behaviour.
Date: 8 Sep 2000 06:43:54
Message: <39b8c2e9@news.povray.org>
: The feature worked exactly as it was designed therefore it was
: not a bug.
  I somehow doubt that they designed "the normals should scale in the usual
way with these patterns but not with these other patterns".
Date: 8 Sep 2000 12:10:34
Message: <jerry-D740FD.09103408092000@news.povray.org>
In article <39b811a8@news.povray.org>, "Rune" <run### [at] inamecom>
>about the strange way the normals worked. When scaling objects, the
>normals changed. For example, in the scenes where I used Blob_Man I
>had to scale my whole scene to fit Blob_Man rather than just scaling
>Blob_Man, because if I scaled Blob_Man his skin and clothed looked all
>wrong. That's very annoying, very unintuitive, and very inconsistent,
The notion that normals should scale along with the objects they are
applied to is very intuitive. If there is a 1-unit bump on a 4-unit
plane, and the plane is doubled, the bump should now be 2 units. That
wasn't the bug. The bug was that POV sometimes scaled the normal and
sometimes didn't.
The bug-fix included (after some wrangling with Nathan, as I recall :*)
the feature of turning normal scaling off, which I am sure is a useful
feature for some. But that scaling included normals was not a bug; the
bug was inconsistency in scaling with normals. (For a longer discussion
of this, see the original postings on this server.)
Jerry
Date: 8 Sep 2000 16:26:06
Message: <39b94b5e@news.povray.org>
> they are applied to is very intuitive.
You may have misunderstood me; I agree with you.
I think it's wrong behaviour when the normal *isn't* scaled proportionally
with the object.
I believe it works correctly in MegaPOV, that is, the normals are scaled
proportionally with objects.
Rune
