POV-Ray : Newsgroups : povray.binaries.animations : Solar Sail v2.0 (mpeg, ~350k) Server Time
8 Oct 2024 02:40:34 EDT (-0400)
  Solar Sail v2.0 (mpeg, ~350k) (Message 1 to 5 of 5)
Subject: Solar Sail v2.0 (mpeg, ~350k)
Date: 4 Sep 2000 13:37:05
Message: <39B3DD7D.B32B39D0@istar.ca>
An updated version. Now a closer pass, more detail, a simpler
background, and a smaller file size.
Simon
Download 'sail.mpg' (354 KB)
Subject: Re: Solar Sail v2.0 (mpeg, ~350k)
Date: 4 Sep 2000 17:16:25
Message: <39b41129@news.povray.org>
much nicer :))
what did you use to do the mpeg conversion?
Date: 4 Sep 2000 19:07:06
Message: <39b42b1a@news.povray.org>
More dramatic I think.  The lens flare from the star seems to be visible
through the sail fabric so that's kind of neat.  Doesn't seem to be so
however, when I pause the player to check it turns out to be an illusion, at
least I suppose it is.  Had you considered the fabric thickness yet?  These
things are always said to be very thin and low mass for them to work well.
Although you do have what is a somewhat bulky mass for it all.  Seems the
most apt way this particular thing would work in your case is for it to be
doing some kind of energy accumulation and transfer.  But now I'm off the
beaten path so I'll leave you with those thoughts  :-)
Date: 4 Sep 2000 19:53:51
Message: <chrishuff-1BF236.18553304092000@news.povray.org>
In article <39b42b1a@news.povray.org>, "Bob Hughes"
<per### [at] aolcom?subject=PoV-News:> wrote:
> Had you considered the fabric thickness yet?  These things are always
Fabric? Everything I have heard talks about a kind of reinforced mylar,
or other high-strength reflective sheet plastic.
Christopher James Huff
Date: 7 Sep 2000 01:08:16
Message: <PB+3OZRwyD2NIayFnQfZwlC1g0Zr@4ax.com>
On Mon, 04 Sep 2000 14:35:57 -0300, Simon de Vet <sde### [at] istarca> wrote:
The vessel definitely appears to be a lot bigger this time -- looking good!
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xs4all.nl/~excel/pb.html
All Basic Code Archives -- http://come.to/abcpackets
