POV-Ray : Newsgroups : povray.binaries.animations : Living Blob Server Time
21 Jul 2025 17:48:29 EDT (-0400)
  Living Blob (Message 1 to 4 of 4)
Subject: Living Blob
Date: 25 Jul 2000 14:45:13
Message: <397DDFCD.5C5083F4@iastate.edu>
This is just an .avi of an accident that came about when I was playing
with Chris Huff's particle patch.
A blobby stream of "paint" is shot into the wall and bounces off it onto
the floor.  Not content with that, the goo
crawls over to the wall, climbs up, and oozes into the surface.
All just one particle system and one emitter.
I don't know exactly why it did this; I think it's because I used
variable elasticity, but I kind of like it.
Mike Wilson
Download 'wall.zip' (45 KB)
Subject: Re: Living Blob
Date: 25 Jul 2000 21:52:32
Message: <397e4460@news.povray.org>
That's very weird.  Tries to get to the target no matter what I suppose.
Date: 26 Jul 2000 16:21:11
Message: <chrishuff-77BD62.15215426072000@news.povray.org>
In article <397DDFCD.5C5083F4@iastate.edu>, Mike Wilson
Hmm, maybe if you increased the component's radius, it would look more
"fluid".
This animation demonstrates one of the problems with my patch: the
liquid's volume isn't conserved. Inter-particle forces can help to fix
this, but they still need work.
The only thing I can think of: did you use wind? It looks like you have
a strong, slightly upward force pulling the particles along the wall.
What do you mean by variable elasticity?
Chris thinks...
Did you decrease the elasticity in the system for each successive frame?
That might make this effect...at first, particles would bounce away from
the wall. Then, as the amount of energy they loose increases, they would
bounce closer to the wall, and eventually would lose enough energy to
slow their fall. If there is wind or gravity pushing them against the
wall, they would slowly "drip" down it.
Date: 27 Jul 2000 09:04:45
Message: <39803342.B3535F59@iastate.edu>
You called it right.  Elasticity is set to "clock-1" and there is a a gravity
vector pulling the particles toward the wall and down to the floor.
The effect you describe is what I was looking for, but I couldn't get the drip
part right.  The particles just seemed to "boil away" rather than slide toward
the floor.  I hadn't tried the ipf{...} stuff yet because it added too much
time to the parse for something I was just fooling around with.
Mike.
