POV-Ray : Newsgroups : povray.binaries.animations : Roll-athon (455 kbbu) Server Time
4 Jul 2026 03:07:02 EDT (-0400)
  Roll-athon (455 kbbu) (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Roll-athon (455 kbbu)
Date: 11 Jul 2000 01:10:24
Message: <396aac40$1@news.povray.org>
Can't help ya with that math stuff, but rolling those balls around on that
surface is definitely impressive.
Dave
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:396a80b4@news.povray.org...
> I changed my bouncing algorithm to a rolling one. The result is below.
> A  one Mb 320 x 240 version is at:
>  http://members.xoom.com/_XMCM/gregjohn/animation.html#POV13
> It's actually the most simple one to date. The particles do not actually
> consider each other's presence (no collision avoidance or bouncing).
> The acceleration of the particle is simply the x & z components of the
> normal at the particle's location. If there's interest, I can make a
> page with the algorithm like I did with the boids...
> I think I  know how to make a texture on the particles themselves rotate
> properly for the motion they make across the surface. It think however
> that my approach would be very inelegant and a real programming
> headache. Any pointers?
> Q: Is there an easy way in matrices to say:
> I rotated <13,5,5>, then <14,4,2>, then,....
> Can I just add these up somehow?
Date: 11 Jul 2000 05:11:25
Message: <396ae4bd@news.povray.org>
that green ball that the camera follows should be invisible no?
Ian
Inkwell: Ian's Homepage
http://www.topcities.com/cartoon/inkwell/index.htm
Greg M. Johnson <"gregj;-)56590\""@aol.c;-)om> wrote in message
Date: 11 Jul 2000 07:22:12
Message: <396B023F.EE3F9891@my-dejanews.com>
It doesn't have to be, it behaves like all the rest, I just picked one that
wasn't all by itself at the end..
Tony asks:
>Do they slow down?
This version had:
#declare actorv[n]=0.9975*actorv[n]+acceleration;
It's funny that at even 0.995* ,  the particles slowed down so quickly it was
boring.....
Date: 11 Jul 2000 09:11:03
Message: <396b1ce7@news.povray.org>
Greg M. Johnson <gre### [at] my-dejanewscom> wrote in message
news:396B023F.EE3F9891@my-dejanews.com...
that
Sorry, that's not what I mean- I'll try to explain... At first when I saw
the animation I was intrigued as to how you did the camera tracking, then I
noticed the green ball that wasn't moving relative to the frame. If the ball
that the camera follows kept all of it's propertys only it was made
invisible, the mystery of the smooth flowing camera work would be retained.
It was just a humble suggestion :-)
Date: 11 Jul 2000 09:22:31
Message: <396B1E77.7441D0E2@my-dejanews.com>
Cool.
Date: 11 Jul 2000 18:00:42
Message: <396B8439.35FC4830@wanadoo.fr>
Hi Greg,
nice animation, but a lot of questions arise !
But OK, I've selected only one question :
In your animation, what is the link between the surface and the position
of the spheres ? Well in other words, how do you know the height (z) of
the surface at a given (x,y) point ? Don't you need this to make any
spheres rolling and not flying over the surface ? In fact I'm looking
for a way, given a height_field object, to know what will be the height
(z axis) of a point given its coordinates (x,y). I suppose it would be
not so much simple to read the source picture used to make the
height_field (considereing the different format possible in use). I
haven't been able to find anything embeded in POV-Ray that let the user
access this value from a povray source file (within a macro in
particular), maybe I have missed it ?
Else, maybe the surface you are using is particular ?
Thank you for any answer !
Denis.
> Tony asks:
> >Do they slow down?
> This version had:
> boring.....
Date: 11 Jul 2000 23:53:21
Message: <396bebb1@news.povray.org>
"Denis Corbin" <cor### [at] wanadoofr> wrote in message
news:396B8439.35FC4830@wanadoo.fr...
| Hi Greg,
I'll let Greg answer too  :-)  but you obviously haven't heard about MegaPov,
or it's 'hf_height_at' keyword which allows you to find any points y
coordinate on the surface of a height field.  HF is along x and z, not x and y
as you had said and the y value is it's height.  Check at:
http://www.nathan.kopp.com/patched.htm
Date: 12 Jul 2000 10:40:48
Message: <396C8239.4933ABF7@my-dejanews.com>
Denis Corbin wrote:
> Hi Greg,
You need x,y,z at any given point AND the normal of the surface.
Here's the algorithm in a nutshell. Yes, it requires the mega pov patch.  First I
define my Surface as an isosurface (I never liked heightfields (;-p  ).
1. Particles have a starting velocity in  x  & z. and a starting position in x & z.
2. A trace function is called for the "new place".
    #declare Downthere=trace(Surface,Oldplace+0.10*Oldvelocity+1000*y, -y, Norm);
3. The velocity is modified by adding the x  and z components of the NORMAL of the
surface at the new place.
    #declare Newvelocity=Oldvelocity+<Norm.x,0,Norm.z>;
4. The new place is modified by adding the NORMAL of the surface times the radius
of the ball.
    #declare Placetostore=Downthere+Norm*ballradius;
Then I store the Placetostore for each ball.
Date: 12 Jul 2000 18:00:41
Message: <396CBED9.17A6BCF7@wanadoo.fr>
Thank you for having open my mind to "MegaPov" !
Denis.
> Denis Corbin wrote:
> > Hi Greg,
> of the ball.
Date: 12 Jul 2000 18:00:43
Message: <396CBEF5.F4BECA2@wanadoo.fr>
Thank you for the link !
Denis.
> Bob
