POV-Ray : Newsgroups : povray.binaries.animations : Color Light Tree Server Time
8 Oct 2024 07:37:01 EDT (-0400)
  Color Light Tree (Message 1 to 10 of 10)
Subject: Color Light Tree
Date: 12 Jul 2000 18:00:46
Message: <396CD1E9.44D9F6E5@wanadoo.fr>
Hi all,
here is my first contribution to this group. But as it is a bit a big
file I will only put the URLs :
- normal size  : http://denis.corbin.free.fr/couleurs.mpg (~ 2 MB)
- reduced size : http://denis.corbin.free.fr/couleurs_half.mpg (~ 1MB)
you are also welcome to visit the rest of the site here at
bye
Denis.
Subject: Re: Color Light Tree
Date: 13 Jul 2000 10:14:47
Message: <396DCDB6.98B3EAFC@my-dejanews.com>
Couldn't see it. It falls outside the standard......
Denis Corbin wrote:
> Hi all,
> bye
> Denis.
Date: 13 Jul 2000 10:27:37
Message: <396DD1C0.ADF3F222@buckosoft.com>
Using what?  It was big (407x???) but M$ media muncher played it.
dik
Date: 13 Jul 2000 13:14:32
Message: <396df8f8@news.povray.org>
I went to have a second look and it failed for me too, using MS Media Player 7 beta.
Strange that
the first time was fine.  My only comment was, and still is, "weird" so I didn't think
that was
enough to say anything before.  Trees of any kind that lively are somehow creepy
things  ;-)
"Dick Balaska" <dic### [at] buckosoftcom> wrote in message
news:396DD1C0.ADF3F222@buckosoft.com...
Date: 13 Jul 2000 13:40:26
Message: <396DFDE5.977BDE16@my-dejanews.com>
What did you use to compile the anim?
Denis Corbin wrote:
> Hi all,
> bye
> Denis.
Date: 13 Jul 2000 18:00:37
Message: <396E3322.4659223@wanadoo.fr>
Thanks for the feed back.
In fact, this is a 352x240 mpeg animation.
I'm using mpegTV top read it, but it also works fine with mpeg_play.
Only the "light" version seems not to be readable using M$ media player
of windows95 (?) sorry for that,
It seems that this is not a Microsoft compliant animation, while it
might be compliant to MPEG standart ... who knows... anyway this is not
important.
for thoses that can't read it, this is a tree that has light as leaves.
Located near a lake, it opens its branches, while leaves (light bulbs)
have their colour changing at the same time.
This is not technically difficult to realize, I've just spent a little
time with composition of the picture, where from in particular the
format, which is 16/9.
Sorry again for inconvenients, (and size of the file --- will try to
make smaller next time),
Denis.
Date: 14 Jul 2000 12:18:25
Message: <396F3838.710EBCF0@wanadoo.fr>
I've used mpeg_encode
Authors (extract from man page) :
Kevin  Gong  -  University  of  California, Berkeley, kev-
       ing### [at] csberkeleyedu
Ketan Patel - University  of  California,  Berkeley,  kpa-
       tel### [at] csberkeleyedu
Dan  Wallach  -  University of California, Berkeley, dwal-
       lac### [at] csberkeleyedu
Date: 15 Jul 2000 16:07:48
Message: <3970c494@news.povray.org>
If it were an issue of m$ inventing their own standard and expecting the
world to comply, I'd be the first to rebel. But I'm suspecting that in
this case the problem with my m$ viewer not seeing your anim  might be
with an unorthodox setting in your editing program, but then again I'm
no professional either.....
Date: 16 Jul 2000 05:10:42
Message: <39717BEF.FD66482C@buckosoft.com>
So then why do you suspect M$ of following any kind of standard other than their own?
Have they *ever* *ever* *ever* followed to the letter *any* standard????
Its Embrace and Extend man, or in this case Embrace and Contract :)
From mpeg.org:
...MPEG-1 sequence which meets the parameter limits
defined in ISO/IEC 11172-2 for constrained parameter bitstreams:
    horizontal_size <= 768
    vertical_size   <= 576
    picture_area    <= 396 macroblocks
    pixel_rate      <= 396x25 macroblocks per second
    vbv_buffer_size <= 20x16384 bit
    bitrate         <= 1856000 bits/second
    motion vector range <= -64...63.5
Just like everything M$ touches, 320x240 has become the de facto standard because
that is what they've decided to do for MPEG-1.  I can generate and play 640x480
MPEG-1s,
(but they look pukey because of the low bitrate and small vbv_buffer size)
Now if i can only solve my problems of encoding 702x480 MPEG-2s, i'll be all set to
try
and burn video CDs. (although my Sony DVD player will play commercial audio CDs but
not
my home burns hmmm...)
dik
Date: 16 Jul 2000 18:00:07
Message: <39722207.F249B369@wanadoo.fr>
Dick Balaska wrote:
> From mpeg.org:
MPEG-1s,
OK, so the problem here is probably because the presented animation has
400 pixels as horizontal size :
   horizontal_size = 400
   vertical_size = 224
   (note : aspect ratio = 16/9 the movie's format)
   vbv_buffer_size = 32*1024 bits
This seems to conforms to the MPEG-1 standard, but not to M$'s
restrictions of this standard.
I'm really sorry for thoses that don't have the choice to use other OS
(or softwares) than Microsoft's ones, sorry that you only know "that"
about computer science. Anyway, I will not remake the animation, because
I have not the time and will to workaround this "bug" (if it is
confirmed that this is the reason of the problem). Moreover this
animation was done first for my own egoist pleasure ; if you can't see
it (or if you don't like, which is your absolute right !) this will not
affect too much the reason why I've done it. ;^)))
I think that this comportment of M$ is unfortunately frequent (to
convice you, see problems with HTML, javascript, and so on) even if here
it is not totally proved that this is the case.
Denis.
