POV-Ray : Newsgroups : povray.binaries.animations : yet another fire animation (yafa ?) [340KB animated gif] Server Time
11 Apr 2026 10:58:42 EDT (-0400)
  yet another fire animation (yafa ?) [340KB animated gif] (Message 1 to 10 of 11)
Subject: yet another fire animation (yafa ?) [340KB animated gif]
Date: 1 Feb 2000 09:28:33
Message: <3896ed91@news.povray.org>
Seeming to be a popular thing to do with POV, here is my attempt at a
fire/flame animation. Anyone know how to make an animation repeat
seamlessly?
Paul Vanukoff
van### [at] primenetcom
Download 'vanukoff_flame1.gif' (341 KB)
Preview of image 'vanukoff_flame1.gif'
Subject: Re: yet another fire animation (yafa ?) [340KB animated gif]
Date: 1 Feb 2000 09:40:51
Message: <3896f073@news.povray.org>
That's a nice one!
I'm not sure I like the oval limit on the flame though... the flame
itself looks like a major forest fire but the outer shape suggests
a candle... I suggest going for a good forest fire...  perhaps with
a wider base and a more ragged top line.
As for the smooth repeat, I don't know how you did this so it is
hard to say.  One guess about the method would be a rotating
wheel (you are looking at the top half as it rotates away from
you).  If this is right you need to make sure your animation runs
for exactly one revolution of the wheel.
If you are relying on randomness in any way you will not get a
smooth repeat.  In this case you might consider having the fire
start from nothing, grow large, and then shrink again... with an
obvious repeat.
Very nice.  Looking forward to more of the same :-)
"Paul Vanukoff" <van### [at] primenetcom> wrote in message
news:3896ed91@news.povray.org...
> seamlessly?
> Paul Vanukoff
Date: 1 Feb 2000 10:41:12
Message: <3896FDC0.85E9E43F@my-dejanews.com>
Could you please post an MPG?
GIF's only play once through clunkily as they load in my reader, and I
don't get to replay them. . .
> seamlessly?
> Paul Vanukoff
Date: 1 Feb 2000 11:30:57
Message: <38970a41@news.povray.org>
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:3896FDC0.85E9E43F@my-dejanews.com...
Sorry. Well, I don't have an MPG encoder handy here (at work). I could post
an avi if so desired. If so, what codec should I use?
Paul Vanukoff
Date: 1 Feb 2000 16:50:43
Message: <38975507.8B69D52D@spiritone.com>
Whenever I want to do a cyclic animation I multiply turbulence by
sin(clock*pi), so basically the amount of turbulence is cyclic as well.
You have to fiddle with it depending on what the clock variable is set
to. If it's range is 0 to 1, then the above should work just fine
> seamlessly?
> Paul Vanukoff
Josh English
eng### [at] spiritonecom
Date: 2 Feb 2000 04:21:02
Message: <3897f6fe@news.povray.org>
post
LOL - what should you be doing?
Date: 2 Feb 2000 08:25:34
Message: <3898304e@news.povray.org>
"Rick [Kitty5]" <pov### [at] dialpipexcom> wrote in message
news:3897f6fe@news.povray.org...
> Rick
:) Here at work? I do on-phone tech support ... I play with POV while I'm
talking to customers ... (if they only knew) ... it's actually the only
place I can get anything done .. there's too much other stuff to do at home
Paul Vanukoff
Date: 9 Feb 2000 17:19:29
Message: <38A1E7F8.D9B8BF2@spiritone.com>
I know exactly how you feel. I do most everyhting here at work, until I need to
render a big file and I take it home.
> > Rick
> Paul Vanukoff
Josh English
Date: 25 Jul 2024 19:55:00
Message: <web.66a2e4f5c37def20edeb1146809b043b@news.povray.org>
> > > Rick
> > Paul Vanukoff
> Josh English
> "May your hopes, dreams, and plans not be destroyed by a few zeros."
I suggest You to start it from zero, then grow, then reduce to zero: lengh = T.
Restart n times, with a n/T phase shift each time.
Thanks.
Date: 29 Jul 2024 15:45:00
Message: <web.66a7efb0c37def2060e0cc3d949c357d@news.povray.org>
> > > > Rick
> > > Paul Vanukoff
> > Josh English
> Thanks.
I think we have a new record for thread necromancy here!
