POV-Ray : Newsgroups : povray.binaries.animations : Martian Dust Storm, URL to the Mpeg Server Time
4 Jul 2026 07:43:06 EDT (-0400)
  Martian Dust Storm, URL to the Mpeg (Message 12 to 21 of 21)
Subject: Re: Martian Dust Storm, URL to the Mpeg
Date: 17 Jan 2000 12:11:07
Message: <38834d2b@news.povray.org>
Too late, I had already downloaded the RCS from the Cyclic site and just didn't
mention I did.  Reason I went looking elsewhere was because they said no
document came with the zip files but that didn't stop me from doing the two
D/L's.
Thanks to your little tutorial here I might be able to use those zips after all.
I just didn't go looking for the reading material for them.  Interesting concept
it is, now I'll end up wondering how this could be a good feature in POV-Ray
itself.
"Jon A. Cruz" <jon### [at] geocitiescom> wrote in message
news:388### [at] geocitiescom...
> Here is one location you can get CVS and RCS from:
> http://www.cyclic.com/pub/
> Here is where RCS is on their servers:
> http://www.cyclic.com/pub/rcs/
> That includes Windows NT versions. (This also works for Windows 9X, since it's
> really just a Win32 version)
> Quickstart:
> * make a C:\bin directory
> * add it to your PATH
> * go there
> * extract rcs57nt.zip
> * extract diff27nt.zip
> * read some docs   :-)
> * go to where you are working on stuff
> * create a 'RCS' directory (all caps, if you can)
> * ci -l *.pov
> Now each one should ask you to enter a description.
> the "-l" option makes it check back out a locked version after the check-in is
> done. A locked version is one that you can edit.
> And whenever you finish editing a .pov file and are at a stage that you might
want
> to keep around, or just before you start doing strange experiments in it...
> ci -l myfile.pov
> voila! you have source control.
> the command
> rcsdiff myfile.pov
> will show you what has changed since your last check-in.
> the command
> rcslog myfile.pov
> will show you a history on that file.
> "My new computer's got the clocks, it rocks
> But it was obsolete before I opened the box" - W.A.Y.
Date: 17 Jan 2000 15:59:45
Message: <38838122.8ACABBF5@pacbell.net>
"Jon A. Cruz" wrote:
> Quickstart:
> * go there
> * ci -l *.pov
> And whenever you finish editing a .pov file and are at a stage that you might want
> ci -l myfile.pov
> the command
> rcsdiff myfile.pov
> the command
> rcslog myfile.pov
That sounds like an aweful lot of work when you can just hit the "save as"
button once in a while to save your work. Source control in a pov file is
almost pointless unless you have an image to go with it to compare the
visual output differences between the two files. <g>
Date: 18 Jan 2000 00:17:44
Message: <3883f778@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38838122.8ACABBF5@pacbell.net...
might want
> > ci -l myfile.pov
> > the command
> > rcsdiff myfile.pov
> > the command
> > rcslog myfile.pov
That was my point though, I have done the File/Save as... routine many times
before and get lot's of similar files that have to be deciphered at a later date
to tell which is which.  Not easy to do, esp. when the rendered image alone
isn't altogether simple to compare.  I may have deleted the good ones and kept
the bad ones trying to go by the most recent date.
Besides, there isn't a "Save as" button, would be a very good idea though.
Date: 18 Jan 2000 09:33:25
Message: <388479b5@news.povray.org>
Here it is again with a different perspective, the camera pans more and the dust
clouds have changed (for the worse? better?).  Well, it's like I've been walking
backward as I try to improve this scene anyway.
The height field helps it I think.  I know I'm going to need blobs or something
like that to use as container objects for the media, the CSG'd cylinders/spheres
are failing me here.
Btw, the clouds are a considerable distance away from the camera, just doesn't
look that way.  The sun is behind them and to the right when the panning stops,
to give an idea about how the shadow is there.  In POV units the hovercraft is
about 0.5 units across and the dust starts about 1000 units away then ends at
about 200 units away from the camera.  So in reality (blurb) still very far off.
If the hovercraft object were 15 meters across that makes the cloud-front 6
kilometers away or approx. 4 miles, if I've figured this right.  Ooooo, it's
vast...!
Without further ado, trial #3 (no one ever saw #2) and then back to work on it.
 http://members.aol.com/persistenceofv/m_ds-hc2.mpg
440KB, 150 frames, 320X240 res. @ 24 fps Mpeg.
Happy viewing!
Date: 18 Jan 2000 09:40:07
Message: <38847b47@news.povray.org>
Mistaken... Very few people, one or two people probably, saw #1.  #2 was the
animation you probably have seen, if at all, and it's still there at:
 http://members.aol.com/persistenceofv/m_ds-ehc.mpg
Date: 18 Jan 2000 14:33:08
Message: <3884C113.B56699A7@t-online.de>
> Bob
Yo Bob!
I just saw both versions of this incredible animation. There are two
things that I think are better in the first one.
First: the scene darkens slowly. This is very good seen on the ground
plane.
Second: also concerning the ground is the fact that shadows are forecast
which makes it more believable (I don't know if the shadows come from
the clouds (sky) or the storm)
The storm itself is better in the second version.
Waiting to see #3 ;-]
Karl
Date: 18 Jan 2000 15:26:33
Message: <3884CBE2.8CADF40@xs4all.nl>
> and the dust
> been walking
> something
> cylinders/spheres
> doesn't
> panning stops,
> hovercraft is
> ends at
> very far off.
> cloud-front 6
> Ooooo, it's
> vast...!
> work on it.
> Happy viewing!
> Bob
The dust in the storm is much better but in this version it seems the
containers are more visible which is a pity.
There's a quirk in the camera movement that is very distracting.
Remco
Date: 19 Jan 2000 02:02:37
Message: <3885618d@news.povray.org>
"Karl Pelzer" <Kar### [at] t-onlinede> wrote in message
news:3884C113.B56699A7@t-online.de...
> plane.
Dust cloud shadow, and it could use breaking up some I think.  It became
apparent that it was going to mess up the whole thing when I wanted to have the
dust roll in slower, it had to be closer for a longer time then.  That meant the
faked realism of it tends to lose credibility, or at least that's how I see it.
I had neglected to do anything about the dust trail of the hovercraft after
getting the height field in, it needs to follow the terrain better but I haven't
found a way to have puffs of dust showing only on the hilltops as it moves yet.
Date: 19 Jan 2000 02:13:38
Message: <38856422@news.povray.org>
"Remco de Korte" <rem### [at] xs4allnl> wrote in message
news:388### [at] xs4allnl...
You don't like the camera panning either huh? :-)  I'm going to smooth it out
more yet leave it generally the same.  It's using the clockmod.inc deceleration
right now with a late start and early finish so it kind of jumps quickly into
motion at the beginning.
I've looked at using blobs for the dust containers now and it isn't pretty, even
more container edges than before.  The attempt at improving the dust patterns
started showing the cylinder/sphere object a lot in  m_ds-hc2.mpg.  Not good...
Btw, I hope everyone who takes a look at these get the whole animation, when I
tested that the upload was okay the first time it chopped away the final part so
the hovercraft never passed by.  On another click of the URL link it all came
through.  It takes time anyway to view as you D/L of course but it had actually
quit too soon before.
Date: 19 Jan 2000 13:14:41
Message: <38854296.FDEFEFEA@melbpc.org.au>
omniVERSE wrote:
> I've seen video of a dust storm in Melbourne Australia, think it was, nice view
> showing it roll into the city.
> Bob
Late reply.
Your interpretation of the Martian dust storm was very close to the actual events
here in Melbourne back in 1984 or 86, I think.  You may get a chance to see it
again, conditions in the south eastern part of Australia, are similar to the
conditions that caused the dust storm all those years ago. 8-)
  ,-._|\  Alex McMurray
 /  Oz  \ ale### [at] melbpcorgau               Melbourne PC User Group.
 \_,--.x/ P.O. Box 215 Melton. Vic.  3337                     Australia
       v
