POV-Ray : Newsgroups : povray.binaries.animations : Vibrating Plate WIP : Re: Vibrating Plate WIP Server Time
16 Nov 2025 17:23:36 EST (-0500)
Date: 8 Mar 2016 08:45:00
Message: <web.56ded7545a67670a5e7df57c0@news.povray.org>
OK, upon further investigation, the interpolation is seriously cracked.
Initially I played around with the starting data set in the SVG,
and then when the interpolated patches started wigging out, I went back and
moved the data points around a bit and moved the camera to look at the spline in
z, y, and z.   It _looked_ ok.
The following are interpolated splines for:
#declare DataSet = array [5]{
array[10]{<-40, 0, 0>, <0,0,0>, <0,0,0>, <-30, 0, 0>, <0,0,0>, <0,0,0>, <-20, 0,
0>, <0,0,0>, <0,0,0>, <-10, 0, 0>},
array[10]{<10, 0, 0>, <0,0,0>, <0,0,0>, <20, 0, 0>, <0,0,0>, <0,0,0>, <30, 0,
0>, <0,0,0>, <0,0,0>, <40, 0, 0>},
array[10]{<20, 20, 0>, <0,0,0>, <0,0,0>, <30, 30, 0>, <0,0,0>, <0,0,0>, <40, 20,
0>, <0,0,0>, <0,0,0>, <50, 25, 0>}
array[10]{<-10, 5, 0>, <0,0,0>, <0,0,0>, <-20, 5, 0>, <0,0,0>, <0,0,0>, <-30, 5,
0>, <0,0,0>, <0,0,0>, <-40, 5, 0>},
array[10]{<40, 5, 0>, <0,0,0>, <0,0,0>, <30, 5, 0>, <0,0,0>, <0,0,0>, <20, 5,
0>, <0,0,0>, <0,0,0>, <10, 5, 0>}
As you can see, I took the top 2 splines and just reordered the data from
beginning to end (and shifted y by 5).   Not looking good.
Someone please page Jerome.  LeForgeron is needed with his mathematical / c++
cape, to bend this Bezier back in line!  Er, I mean curve!  No, wait - line.
Download 'retrobeziernegativeproblem.png' (20 KB)
Preview of image 'retrobeziernegativeproblem.png'
