POV-Ray : Newsgroups : povray.binaries.animations : Uberpov persistent feature for animation of big scene : Re: Uberpov persistent feature for animation of big scene Server Time
16 Jul 2026 10:23:04 EDT (-0400)
Date: 6 Jan 2018 22:11:26
Message: <5a518fde$1@news.povray.org>
Am 07.01.2018 um 01:04 schrieb Kenneth:
> Do you mean like this... (I'm using his very first texture as an example)...
[snip]
> *If* that's correct, then I do see that the #persistent is
> only invoked on the first animation frame; all the following frames will use the
> already-'declared' APPID_340814880_342762184... because it's 'persistent.'
> Am I thinking right?
Yes.
> It looks like most of his entire scene is in a union, so here's a question:
> Instead of having to wrap each and every #persistent FOO = ......  in an #ifndef
> block, could the entire UNION have only *one* #ifndef block around it instead?
> Or, maybe like...
> #ifndef(FOO)
> #persistent FOO =
> union{.....
> ........ everything (NO #persistent for any of these items, but regular #declares
> or #locals, if needed).........
> #else
> #end
> object{FOO}
I presume you mean something like this:
    #ifndef(MyBigFatUnion)
      #define Blah = ...
      #define Dunno = ...
      #persistent MyBigFatUnion = union {
        object { Blah }
        object { Dunno }
    #endif
    object { MyBigFatUnion }
That should indeed work fine.
