POV-Ray : Newsgroups : povray.binaries.animations : Mysterious vanishing isosurface : Re: Mysterious vanishing isosurface Server Time
12 Nov 2026 05:20:06 EST (-0500)
Date: 9 Dec 2016 00:09:49
Message: <584a3c9d$1@news.povray.org>
On 12/9/2016 12:02 AM, clipka wrote:
> Am 09.12.2016 um 03:36 schrieb Mike Horvath:
>> If I rotate the camera 90 degrees around the x axis, the isosurface
>> disappears.
> My guess would be that on the "bottom" side of the shape, the function
> has a much stronger gradient, so that when POV-Ray starts searching the
> contained_by volume for intersection points starting from that side, it
> finds incredibly huge values and thinks, "oh, I must still be VERY far
> from the surface" -- advances a good deal, _skipping_ over the actual
> body of the shape, and finds itself still outside, concluding that there
> is no shape at all.
> You must either increase max_gradient to fit even that portion of the
> shape, or somehow find a way to get a nicer gradient down there.
Is there any "adaptive" form of max_gradient, so the setting is only
high where needed?
Mike
