POV-Ray : Newsgroups : povray.beta-test : Povray-3.7.0.RC6 successfully compiled on MacBook Pro MAC OS X 10.7.5 Server Time
25 Apr 2026 12:26:49 EDT (-0400)
  Povray-3.7.0.RC6 successfully compiled on MacBook Pro MAC OS X 10.7.5 (Message 1 to 2 of 2)
Subject: Povray-3.7.0.RC6 successfully compiled on MacBook Pro MAC OS X 10.7.5
Date: 23 Dec 2012 10:10:01
Message: <web.50d71e3296e40f94be007bed0@news.povray.org>
In the following document, I give all the modification I've done to make POVRAY
to compile.
The modifications should be included in the configuration process. But I don't
First, let give all the important technical data about my system.
Then I explain the changes I've made to the code.
You **will** be able to download the modified code on:
http://beurive.com/data/povray.zip
Please: the upload of the file is **slow**. It's not finished yet...
I compile using the GNU environment, installed via MacPorts.
POVRAY version: povray-3.7.0.RC6
$ machine
  i486
$ sw_vers
  ProductName:    Mac OS X
  ProductVersion: 10.7.5
  BuildVersion:   11G63
$ gcc -v
  Target: i686-apple-darwin11
  Thread model: posix
  gcc version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)
$ port list boost pth jpeg libpng tiff zlib
  boost          @1.52.0         devel/boost
  pth            @2.0.7          devel/pth
  jpeg           @8d             graphics/jpeg
  libpng         @1.5.13         graphics/libpng
  tiff           @3.9.7          graphics/tiff
  zlib           @1.2.7          archivers/zlib
Configure
../configure COMPILED_BY="tes### [at] testcom" \
            CXX=g++ \
            CXXCPP="g++ -E" \
            LDFLAGS='-L/opt/local/lib -lboost_system-mt' \
            CXXFLAGS="-DMACOS10_7_5"
Note: see "Problem 2" for "CXXFLAGS".
Problem 1:
"uint" is not defined.
You need to include <sys/types.h>.
I added it in the file "./vfe/unix/syspovconfig.h".
Problem 2:
"lseek64" is not defined in file "./source/base/image/image.cpp".
I added a dirty macro in "./vfe/unix/syspovconfig.h".
#ifdef MACOS10_7_5
#define POV_LSEEK(a,b,c) lseek(a,b,c)
#else
#define POV_LSEEK(a,b,c) lseek64(a,b,c)
#endif
Then I replaced "lseek64" by "POV_LSEEK" in file
Note : You need to add a CXXFLAGS to the command "configure".
Problem 3:
Thread-local storage not supported for this target.
You need to comment 4 macros in the file ./vfe/unix/syspovconfig.h.
// #define DECLARE_THREAD_LOCAL_PTR(ptrType, ptrName)                __thread
ptrType *ptrName
// #define IMPLEMENT_THREAD_LOCAL_PTR(ptrType, ptrName, ignore)      __thread
ptrType *ptrName
// #define GET_THREAD_LOCAL_PTR(ptrName)                             (ptrName)
// #define SET_THREAD_LOCAL_PTR(ptrName, ptrValue)                   (ptrName =
ptrValue)
Problem 4:
"boost::TIME_UTC" is not defined.
You need to replace it by "boost::TIME_UTC_" in :
  o ./source/backend/scene/view.cpp.
  o ./vfe/vfesession.cpp
  o ./vfe/vfepovms.cpp
I have added the following code into "./vfe/unix/syspovconfig.h":
#include "boost/version.hpp"
#if BOOST_VERSION >= 105000
#define POV_BOOST_UTIME boost::TIME_UTC_
#else
#endif
Then replace "boost::TIME_UTC" by "POV_BOOST_UTIME" everyhere.
Best regards,
Denis
Subject: Re: Povray-3.7.0.RC6 successfully compiled on MacBook Pro MAC OS X 10.7.5
Date: 23 Dec 2012 11:55:01
Message: <web.50d7372cf9da39d9be007bed0@news.povray.org>
Hello,
While compiling Povray-3.7.0.RC6 on MacBook Pro MAC OS X 10.7.5, I have problem
with "uint". I add to include <sys/types.h>.
In order to increase the portability, I suggest to replace every occurrence of
"uint" by "unsigned int".
Unlike "uint", "unsigned int" is always defined. Therefore, I suggest to replace
every occurrence of "uint" by "unsigned int".
There are only  3 lines to modify, distributed in 2 files.
  -  ./vfe/unix/vfeplatform.h (2 lines).
  -  ./vfe/vfesession.h (1 line).
It is a small modification, bu I think it worth it.
Note: find . -type f -name "*.h" -exec grep -H 'uint' {} \;
Best regards,
Denis
