POV-Ray : Newsgroups : povray.beta-test : 3.7RC6 Text Editor bug Server Time
12 Jul 2025 17:43:46 EDT (-0400)
  3.7RC6 Text Editor bug (Message 1 to 3 of 3)
Subject: 3.7RC6 Text Editor bug
Date: 20 Nov 2012 23:05:01
Message: <web.50ac5225ef20c58884c279110@news.povray.org>
Trying to collapse lines to suit my personal style, the editor deletes
non-highlighted text.
Consider the lines:
      color <1,1,1>
What I want to end up with is
    pigment { color <1,1,1> }
I tab to the end of the pigment line, just right of the opening brace, hold down
Shift and tab to the end of the white-space preceding the color keyword, then
press Space.  This should change the text to read as:
But instead the editor removed additional text and the result was
    pigment { 1,1,1>
It appears the editor is moving down a full line, to the same column, and not
replacing only the highlighted segment, as expected.
The workaround, in this case, is to avoid using highlighting and make the
changes character-by-character.
This only appears to be an issue when end-of-line appears in the highlighted
text.
My apologies if this is a duplicate issue.
Subject: Re: 3.7RC6 Text Editor bug
Date: 21 Nov 2012 03:01:35
Message: <50ac8a5f$1@news.povray.org>
I confirm this odd behaviour.
Date: 21 Nov 2012 04:54:48
Message: <50aca4e8@news.povray.org>
Am 21.11.2012 09:01, schrieb Thomas de Groot:
Yes, this is a known problem with a known solution that will be part of
the next release (the solution, not the problem ;-)).
