![](/i/fill.gif) |
Trying to collapse lines to suit my personal style, the editor deletes
non-highlighted text.
Consider the lines:
color <1,1,1>
What I want to end up with is
pigment { color <1,1,1> }
I tab to the end of the pigment line, just right of the opening brace, hold down
Shift and tab to the end of the white-space preceding the color keyword, then
press Space. This should change the text to read as:
But instead the editor removed additional text and the result was
pigment { 1,1,1>
It appears the editor is moving down a full line, to the same column, and not
replacing only the highlighted segment, as expected.
The workaround, in this case, is to avoid using highlighting and make the
changes character-by-character.
This only appears to be an issue when end-of-line appears in the highlighted
text.
My apologies if this is a duplicate issue.
![](/i/fill.gif) |
![](/i/fill.gif) |
Am 21.11.2012 09:01, schrieb Thomas de Groot:
> I confirm this odd behaviour.
Yes, this is a known problem with a known solution that will be part of
the next release (the solution, not the problem ;-)).
![](/i/fill.gif) |
