POV-Ray : Newsgroups : povray.beta-test : Please put back the command line error messages Server Time
5 May 2024 06:36:58 EDT (-0400)
  Please put back the command line error messages (Message 1 to 6 of 6)
Subject: Please put back the command line error messages
Date: 2 Nov 2012 12:55:02
Message: <web.5093f9d9e429c6af85de7b680@news.povray.org>
POV-Ray 3.7 does not give sufficient information when there is an error on the
command line.  When I issue a line such as:
   povray 'spine.ini[Atlas superior]' rainbow.ini
I get back:
   Problem with option setting
   povray spine.ini[Atlas superior] rainbow.ini
   Failed to parse command-line option
Usually in such situations, I can stare at the screen for 5, 10 minutes until my
eyeballs bleed, and then I figure out what I overlooked or where my pinky finger
slipped.  But I shouldn't even have to do that.  And now, in the above case, I'm
stumped.  I just can't figure out what's wrong with the command line.
POV-Ray 3.6 always gave sufficient information; at a glance, I could spot the
error.  But in the above case, 3.6 ran successfully.  Something must have
changed in the front end between 3.6 and 3.7, but I can't tell what, especially
since a command line that was perfectly legal in 3.6 no longer works.
I've seen this issue raised before (and FS#41 was issued, but it was closed).
In two cases, the error was in the front end itself (FS#194 and FS#234), and it
was up to the users to figure out that they did nothing wrong.  I'll ask again:
can we please have our error messages back?
POV-Ray version: 3.7.RC6
Operating system: openSUSE Linux 12.1
__________________________________________________
The above case is from a set of scenes that I haven't worked with for several
years.  These are the relevant .ini files:
===== spine.ini ==================================
Version=3.6
+is!spine.pov
+L/home/ricky/Documents/POV-Ray/skeleton ;This isn't the problem,
                                         ;because it works in 3.6.
+w180 +h180
[Lateral/d]
+ospine-l +h540
declare=Yaw=90
declare=Lift=0.2
declare=Nudge=0.5
[Dorsal]
+ospine-d +h540
declare=Yaw=0
declare=Lift=0.2
[Lateral/v]
+ospine+l +h540
declare=Yaw=-90
declare=Lift=0.2
declare=Nudge=-0.5
[Oblique]
+ospine-o +h540
declare=Yaw=-135
declare=Lift=0.2
declare=Nudge=-0.3
[Ventral]
+ospine-v +h540
declare=Yaw=180
declare=Lift=0.2
[Atlas superior]
+ovc1-s +w210
declare=vStart=23
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-90.0
declare=Lift=-0.1
declare=Height=2.8
[Axis superior]
+ovc2-s
declare=vStart=22
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-90.0
declare=Lift=-0.3
[C3 superior]
+ovc3-s
declare=vStart=21
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-88.11
declare=Lift=-0.25
declare=Height=2.3
[C4 superior]
+ovc4-s
declare=vStart=20
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-84.75
declare=Lift=-0.3
declare=Height=2.4
[C5 superior]
+ovc5-s
declare=vStart=19
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-80.34
declare=Lift=-0.35
declare=Height=2.5
[C6 superior]
+ovc6-s
declare=vStart=18
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-75.30
declare=Lift=-0.4
declare=Height=2.6
[C7 superior]
+ovc7-s
declare=vStart=17
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-70.05
declare=Lift=-0.45
[T1 superior]
+ovt1-s
declare=vStart=16
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-65.01
declare=Lift=-0.4
[T2 superior]
+ovt2-s
declare=vStart=15
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-65.0
declare=Lift=-0.3
[T3 superior]
+ovt3-s
declare=vStart=14
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-70.7
declare=Lift=-0.15
[T4 superior]
+ovt4-s
declare=vStart=13
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-76.1
declare=Lift=0
[T5 superior]
+ovt5-s
declare=vStart=12
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-81.2
declare=Lift=0.05
[T6 superior]
+ovt6-s
declare=vStart=11
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-86.0
declare=Lift=0.10
[T7 superior]
+ovt7-s
declare=vStart=10
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-90.5
declare=Lift=0.07
[T8 superior]
+ovt8-s
declare=vStart=9
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-94.7
declare=Lift=0.04
[T9 superior]
+ovt9-s
declare=vStart=8
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-98.6
declare=Lift=0.01
[T10 superior]
+ovt10-s
declare=vStart=7
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-102.2
declare=Lift=-0.02
[T11 superior]
+ovt11-s
declare=vStart=6
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-105.5
declare=Lift=-0.05
[T12 superior]
+ovt12-s
declare=vStart=5
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-108.5
declare=Lift=-0.1
[L1 superior]
+ovl1-s
declare=vStart=4
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-105.8
declare=Lift=-0.15
[L2 superior]
+ovl2-s
declare=vStart=3
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-101.1
declare=Lift=-0.15
[L3 superior]
+ovl3-s
declare=vStart=2
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-94.4
declare=Lift=-0.10
[L4 superior]
+ovl4-s
declare=vStart=1
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-85.7
declare=Lift=-0.05
[L5 superior]
+ovl5-s
declare=vStart=0
declare=Dbg=1
declare=Yaw=180
declare=Pitch=-75
===== rainbow.ini ================================
+a0.1 -j
declare=sotdw=0.5
declare=mVC1=439
declare=mVC2=430
declare=mVC3=21
declare=mVC4=23
declare=mVC5=25
declare=mVC6=26
declare=mVC7=487
declare=mVT=430
declare=mVT1=439
declare=mVT9=431
declare=mVT10=433
declare=mVT11=435
declare=mVT12=437
declare=mVL1=439
declare=mVL2=431
declare=mVL3=433
declare=mVL4=435
declare=mVL5=437
Subject: Re: Please put back the command line error messages
Date: 2 Nov 2012 14:04:09
Message: <50940b19@news.povray.org>
Am 02.11.2012 17:50, schrieb Cousin Ricky:
> I get back:
Please try
     povray '"spine.ini[Atlas superior]"' rainbow.ini
see FS#42; I did notice this unexpected behaviour a while ago, but
didn't realize until now that it is actually an error (being different
in behaviour from 3.6), so originally it was categorized and titled as a
feature request.
Date: 29 Dec 2012 10:05:01
Message: <web.50df05fef429d33b85de7b680@news.povray.org>
> > I get back:
> Please try
Thanks for the tip.  However, my point is that I shoudn't have to stare at the
command line for 5 or 10 minutes trying to figure out why the front end doesn't
like it.  The front end should give more information about what part of the
command line it failed to parse.
I just spent 20 minutes (no exaggeration) trying to figure out why a command
that worked just a few minutes earlier stopped working.  I tried retyping the
command, fooling around with quotation marks, changing the .ini file section,
and just plain staring before I figured out that I was in the wrong directory.
If the front end had reported that it couldn't find the .ini file, I would have
noticed my mistake in half a second.
Date: 29 Dec 2012 11:45:52
Message: <50df1e40$1@news.povray.org>
Le 29/12/2012 16:02, Cousin Ricky nous fit lire :
>>> I get back:
>> Please try
Would have the command line splitted by argument (hence displaying:
* povray
* spine.ini[Atlas
* superior]
* rainbow.ini
) helped ?
I'm afraid line-feed might not be the right character to use, IIRC my
very long command line.
May be some other markup around each element ?
(it's in vfe/unix/unixconsole.cpp circa line 541)
Date: 29 Dec 2012 17:00:00
Message: <web.50df6625f429d33b85de7b680@news.povray.org>
> * povray
> * spine.ini[Atlas
> * superior]
> * rainbow.ini
> ) helped ?
A parse tree might be overkill (although it would have helped in this particular
example), and yet wouldn't necessarily give sufficient helpful information.  You
can split "povray nexiste[pas]" any way you want, but that won't tell you that
the file is in a different directory.  The way POV-Ray 3.6 handles command line
errors is fine.  Why was it changed?
This is sample output from a POV-Ray 3.7 call:
______________________________________________________________________
ricky@linux-g9n0:~/Documents/POV-Ray/vseries> povray nexiste[pas]
povray: This is a RELEASE CANDIDATE version of POV-Ray. General distribution is
discouraged.
povray nexiste[pas]
This is sample output from a POV-Ray 3.6 call ("povray36" is aliased to the 3.6
executable):
ricky@linux-g9n0:~/Documents/POV-Ray/vseries> povray36 nexiste[pas]
Could not find file 'nexiste.ini'
Cannot open INI file 'nexiste'.
Cannot process command-line due to a parse error.
This is not a valid command-line. Check the command-line for syntax errors,
correct them, and try again!
Valid command-line switches are explained in detail in the reference part of the
documentation.
To get a short list of command-line switches, use either the '-h', '-?', '-help'
or '--help' switch.
Failed to render file due to error(s)!
The first two lines of the 3.6 error message tell me exactly what I need to
know.
Come to think of it, maybe I should just use 3.6 whenever I run across a problem
like this.  Nevertheless, this won't help where the front end changes, such as
with new command line switches, new quotation mark behavior, or new bugs.  It's
also a rather kludgey way to handle a problem with a new and improved software
version.
Date: 30 Dec 2012 03:22:15
Message: <50dff9b7$1@news.povray.org>
It was not actually changed: It is just that the errors are detected at
different places in the code now, and that some error messages aren't output
any more, which is an oversight, not an intentional omission. The command
line error message output simply had low priority so far.
	Thorsten
