POV-Ray : Newsgroups : povray.beta-test : Render Window: Improvement Proposal Server Time
25 Apr 2026 16:15:32 EDT (-0400)
  Render Window: Improvement Proposal (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Render Window: Improvement Proposal
Date: 28 Oct 2012 03:36:51
Message: <508ce093$1@news.povray.org>
On 27-10-2012 20:28, Alain wrote:
> If you want to render a specific part of an image, and keep that part
> for successive renders, you can hold the shift key as you draw the
> sellection rectangle.
> Next time you use the Run button, it will render only that area.
You made my day! I did not know that, about the shift button! Where, in
the Docs, is this described? I cannot find it. Also, how do you return
to full image render?
Date: 28 Oct 2012 04:00:37
Message: <508ce625$1@news.povray.org>
Help 3.1.2.2.3 Partial Output Options
It puts a command into the command box like (+sc0.142678 +sr0.143573
+ec0.339174 +er0.275459)
To get back to full image, just remove the command.
Regards
Date: 28 Oct 2012 04:35:01
Message: <508cee35$1@news.povray.org>
Right! I know about this section indeed and I often use thes command
line options. However, the /shift/ trick is /not/ described there  :-)
Date: 28 Oct 2012 05:30:56
Message: <508cfb50$1@news.povray.org>
I found it by accident when I selected an area on the image and a pop up
window appeared, with the info.
Maybe it is the "Easter Egg" that I never found.
Regards
Date: 28 Oct 2012 07:38:36
Message: <508d193c$1@news.povray.org>
It must be indeed, but one worth its weight in POV-gold...
Date: 28 Oct 2012 11:31:13
Message: <508d4fc1$1@news.povray.org>
well ... I at least learned it from the message box that pops up
directly after you drag *without* shift. But then, I have the bad habit
of checking the entire text before accepting anything with "OK" ;)
Date: 29 Oct 2012 03:52:05
Message: <508e35a5$1@news.povray.org>
<blush> You know now what I do /not/ do....
I am so used to that screen that I never take the time to really read
it. I don't know why, but I feel a bit stupid this morning :-)
Date: 30 Oct 2012 10:02:16
Message: <508fdde8$1@news.povray.org>
don't worry we all have some blind spots ;)
Date: 30 Oct 2012 11:29:35
Message: <508ff25f@news.povray.org>
> Thomas
Very easy to find, just read the dialog box that pop up every time you
sellect a given area to render.
To return to normal, full image rendering, just clear the command line box.
Date: 31 Oct 2012 04:33:08
Message: <5090e244$1@news.povray.org>
Strange how one can sometimes be blind to the most obvious things :-)
I have now also the /real/ answer to my question in this ng, on april
22nd 2011: Missing feature: Rerun
With time, everything becomes clear.
