On 28-10-2012 16:31, Christian Froeschlin wrote:
> well ... I at least learned it from the message box that pops up
> directly after you drag *without* shift. But then, I have the bad habit
> of checking the entire text before accepting anything with "OK" ;)
<blush> You know now what I do /not/ do....
I am so used to that screen that I never take the time to really read
it. I don't know why, but I feel a bit stupid this morning :-)
Subject: Re: Render Window: Improvement Proposal
Date: 30 Oct 2012 10:02:16
Message: <508fdde8$1@news.povray.org>
don't worry we all have some blind spots ;)
> On 27-10-2012 20:28, Alain wrote:
>> If you want to render a specific part of an image, and keep that part
>> for successive renders, you can hold the shift key as you draw the
>> sellection rectangle.
>> Next time you use the Run button, it will render only that area.
> You made my day! I did not know that, about the shift button! Where, in
> the Docs, is this described? I cannot find it. Also, how do you return
> to full image render?
> Thomas
Very easy to find, just read the dialog box that pop up every time you
sellect a given area to render.
To return to normal, full image rendering, just clear the command line box.
Strange how one can sometimes be blind to the most obvious things :-)
I have now also the /real/ answer to my question in this ng, on april
22nd 2011: Missing feature: Rerun
With time, everything becomes clear.
