POV-Ray : Newsgroups : povray.beta-test : difference bug Server Time
10 May 2025 01:17:44 EDT (-0400)
  difference bug (Message 1 to 10 of 10)
Subject: difference bug
Date: 16 Jul 2012 15:25:00
Message: <web.500469a1adf6cd217f523b7e0@news.povray.org>
I'm not sure exactly where this bug lies, but pinning it on difference seems to
be the most logical thing.  Here's some sample code:
#version 3.7;
global_settings {
  max_trace_level 256
  ambient_light White
  assumed_gamma 1.0
  location <0,10,0>
  look_at <0,0,0>
light_source {
  <1000,1000,0>
  color White
plane {
  y, -10
  pigment { hexagon Green, White }
box {
  <-0.9999, -0.9999, -0.9999>, <0.9999, 0.9999, 0.9999>
  pigment { checker Violet, Yellow }
difference {
  box {
<-1.0000149999,-1.0000149999,-1.0000149999>,<1.0000149999,1.0000149999,1.0000149999>
  box { <-1, -1 ,-1>,<1,1,1> }
    transmit 0
  finish {
    ambient 0
    diffuse 0
    conserve_energy
    reflection {
      1
      fresnel on
    specular 0
    roughness 0.001
  interior {
    ior 1/sqrt(2)
difference {
  box { <-1.00003,-1.00003,-1.00003>,<1.00003,1.00003,1.00003> }
  box { <-1.000015, -1.000015 ,-1.000015>,<1.000015,1.000015,1.000015> }
    transmit 1
  finish {
    ambient 0
    diffuse 0
    conserve_energy
    reflection {
      0
      fresnel on
    specular 0
    roughness 0.001
  interior {
    ior 1
If you render the above, you should see a black square with a backdrop of
hexagons (the plane).  However, you see a checkered square with a backdrop of
hexagons.  If you comment out the second difference (the one with the ior of 1),
you will see what you are supposed to see.  There should, however, be no
difference since an ior of 1 corresponds to air!  When I rendered this with
POV-Ray 3.6, I saw a black square which confirms that this a bug that has crept
in during the development of 3.7.
- Chaanakya
Subject: Re: difference bug
Date: 16 Jul 2012 18:35:58
Message: <5004974e$1@news.povray.org>
Am 16.07.2012 21:21, schrieb Chaanakya:
This is actually not really a bug, but merely a (currently) inevitable
limitation: When tracing a ray from some surface, POV-Ray must make sure
to ignore intersections with the very same or a coincident surface. To
be robust against rounding errors, it does this by comparing the
distance to the intersection with a certain minimum distance threshold.
The threshold was changed during the development of 3.7 (I'm not sure
why though).
Date: 17 Jul 2012 08:50:00
Message: <web.50055ed5808946837f523b7e0@news.povray.org>
> why though).
What was the threshold in 3.6?  I think the threshold is on the order of 1e-6
now if I'm not mistaken...
Date: 17 Jul 2012 09:20:01
Message: <web.500565e7808946837f523b7e0@news.povray.org>
> > why though).
I found that it was changed (in 3.7) to 1e-4 - I changed it to 1e-9 to see if
that makes a difference.  I will report back.  Thanks for pointing me in that
direction!
- Chaanakya
Date: 17 Jul 2012 09:40:00
Message: <web.50056a95808946837f523b7e0@news.povray.org>
to
> > > why though).
> direction!
> - Chaanakya
I at least fixed the problem that I mentioned above - the box now renders
correctly.  I changed the following values in source/backend/configbackend.h:
#define SMALL_TOLERANCE 1.0e-6
#define MAX_DISTANCE 1.0e10
#define MIN_ISECT_DEPTH 1.0e-9
and the box now renders correctly.  Thanks again!
Sincerely,
Chaanakya
Date: 17 Jul 2012 10:11:00
Message: <50057274@news.povray.org>
> why though).
Seems to be the same issue addressed in bug task #246, reported in
"Scale Limit?" above.
Date: 17 Jul 2012 15:57:02
Message: <5005c38e$1@news.povray.org>
>> seems to
> why though).
There almost needs to be like either an "infinite" math, which isn't
practical, or some sort of "extra" math, which tells it, when running
across these things, "Are you inside object A, instead of B, and from
which direction are you approaching that side, as a result?". No idea if
that is even practical, but... coincident surfaces (and obviously
intersection code) currently require tricks that, from a practical
standpoint "break" the actual physics of the object, by requiring things
like, "leave a small gap between the contents of a cup, and the actual cup.
This is, kind of a silly situation, especially if you where trying to,
say, "fill" the cup using something like someone's liquid physics
simulations. Now, testing which thing you where just "inside" on the way
to the surface won't work in all cases, probably, but being "aware" that
the surface being hit has its "backside" in front of you, instead of
behind you, in principle, might cut down on some of the issues. Or, it
might create others, but it would, I would think, create a kind of
"sorting", where the side you are headed for would always be, "Belonging
to what I just came from, first, then the other one.", without regard to
any rounding issues.
Or am I just not getting the problem again? lol
Date: 17 Jul 2012 16:28:02
Message: <5005cad2$1@news.povray.org>
Am 17.07.2012 21:57, schrieb Patrick Elliott:
Coincident surface issues /are/ a major PITA - this is known to the dev
team, and it's pretty high on the agenda. But not for 3.7, that's for sure.
Date: 18 Jul 2012 03:32:26
Message: <5006668a$1@news.povray.org>
But I hope the threshold is?
Date: 23 Jul 2012 13:34:45
Message: <500d8b35$1@news.povray.org>
> why though).
Is it a compiled constant for performance issues or could it
be turned into a global setting? If there are reasons to change
it by a factor of 100 it might be useful as a parameter.
