POV-Ray : Newsgroups : povray.beta-test : Segmentation fault with animation of large image Server Time
25 Apr 2026 18:08:25 EDT (-0400)
  Segmentation fault with animation of large image (Message 11 to 17 of 17)
Subject: Re: Segmentation fault with animation of large image
Date: 29 Jan 2012 15:53:23
Message: <4f25b1c3@news.povray.org>
On 29.01.12 12:11, Le_Forgeron wrote:
> Le 28/01/2012 22:09, Thorsten Froehlich nous fit lire :
>> On 28.01.12 19:54, Le_Forgeron wrote:
>>>> I have not run an animation this large in Windows, so I don't know if
>>>> it's a
>>>>>   problem there.
>>> Well, if someone can try that on Windows (animation, picture size bigger
>>> in any dimensions, including both, than the available display)
>> Why would a crash in Unix-specific code have any impact on
>> Windows-specific code?
> Not directly, but a similar error might have been copied&pasted... or
> served as a common design (by same authors or like, so it was an error
> on unix, it might also on others.. I just do not know their ways of
> handling the scaling (if any) of large pictures)
Well, xcb_io.c is a system library and not POV-specific, so it cannot be a
POV-Raz bug. Googling suggests the assertion failure is actually a race
condition in some ATI binary-only graphics drivers...
	Thorsten
Date: 29 Jan 2012 17:38:11
Message: <4f25ca53@news.povray.org>
>>>> it's a
>>>>>   problem there.
> Better check while at it than sorry in 8 months.
Using the Windows version, if the image is larger than the display, the
image is not scaled but scroll bars will appears.
If you maximize the display window, then the image is scaled.
Tested at 3200 by 1200 (1600 by 1200 display) and got no problem when
starting the second frame with display maximized.
Date: 29 Jan 2012 20:22:00
Message: <4f25f0b8$1@news.povray.org>
>>>>> it's a
>>>>>> problem there.
>>>> bigger
> a POV-Raz bug. Googling suggests the assertion failure is actually a
> race condition in some ATI binary-only graphics drivers...
> Thorsten
Last month I abandoned my upgrade to opensuse12.1 (same as original
poster) because of a problem I was seeing with the ATI drivers. I didn't
get to do a postmortem on the upgrade to figure out what happened, I
just went back to 11.2 instead ... When I saw the initial post I
couldn't remember why xcb_io.c looked awful familiar. Thanks for the
nudge ;-)
Date: 30 Jan 2012 08:07:19
Message: <4f269607$1@news.povray.org>
I was talking about the missing .reserve() (and the loop of
initialisation) of m_PxCount in TakeOver (when the crash happened on the
second frame, it's because m_PxCount is indeed an empty vector, so it
does not like Povray accessing any of its element).
Ambiguous quote from previous messages are my fault, all my fault, all
my big fault.
Alain did check the windows port, seems fine. That's a good news.
what about the Mac port ? (or is it unix based now ?)
The xcb_io.c issue is yet another issue, but I cannot reproduce it (I'm
on Ubuntu with a nvidia card). I could use a VirtualMachine (VM) to get
an OpenSuse, but that won't create any Ati card.
Date: 30 Jan 2012 12:05:47
Message: <4f26cdeb$1@news.povray.org>
no promises ... but I'll try to massage my opensuse12.1 upgrade in the
proper direction this week, perhaps with some luck ATI driver issues
have been resolved and they'll have a new download
Date: 31 Jan 2012 11:33:32
Message: <4f2817dc@news.povray.org>
  If the ATI linux drivers are causing you problems, try using an older
version of the drivers. In my box 10-8 works ok.
  (Remember that you need to run aticonfig after installing a driver
which version deviates significantly from what you currently have.
I have noticed that the xorg.xonf files they generate are not always
compatible.)
Date: 5 Feb 2012 11:17:49
Message: <4f2eabad$1@news.povray.org>
> compatible.)
yep ... found that the Modules section in xorg.conf was empty. I'm good
to go now, and have latest drivers from geeko repository and all appears
fine ... now let's see if I can do a povray build ;-)
