POV-Ray : Newsgroups : povray.beta-test : Doubled errors Server Time
25 Jun 2024 23:59:41 EDT (-0400)
  Doubled errors (Message 1 to 8 of 8)
Subject: Doubled errors
Date: 18 Jul 2011 05:15:01
Message: <web.4e23f93edfdc922df1a674c50@news.povray.org>
Is there any reason, why parse errors are seen twice:
File 'example.pov' line 10: Parse Error: No matching } in 'pigment', { found
 instead
 instead
Fatal error in parser: Cannot parse input.
Render failed
In this case, there is only one '{' in line 10.
Povray is 3.7 RC3.
Subject: Re: Doubled errors
Date: 18 Jul 2011 10:59:13
Message: <4e244a41$1@news.povray.org>
>   instead
>   instead
> Render failed
> Povray is 3.7 RC3.
http://www.catb.org/~esr/faqs/smart-questions.html
Date: 18 Jul 2011 11:26:48
Message: <4e2450b8$1@news.povray.org>
As Thorsten probably intended to convey, answering this
question requires to see a small code sample that reproduces
the effect.
Date: 18 Jul 2011 16:05:00
Message: <web.4e2490c7f2a3198ff1a674c50@news.povray.org>
> the effect.
Every now and then, if there is any problem which produce a "parse error",
exactly same error message is printed 2 times. This effect is totally
independent on actual reason of error.
2 examples:
File 'a.pov' line 2: Parse Error: Expected 'numeric expression', } found instead
Render failed
a.pov:
global_settings {assumed_gamma 1.5}
box {<-0.5, -0.5, -0.5>, }
light_source {<4, 5, -5>, rgb <1, 1, 1>}
camera {location <5, 5, -5> look_at <0, 0, 0>}
File 'b.pov' line 2: Parse Error: Expected 'object', undeclared identifier 'foo'
 found instead
 found instead
Render failed
b.pov:
object { foo }
Povray: 3.7 RC3
Host computer: 64 bit Debian sid, AMD Phenom X4 9950, 8GB ram
Date: 19 Jul 2011 09:46:37
Message: <4e258abd$1@news.povray.org>
On 07/18/2011 05:00 PM, Timo Poikola wrote:
> 2 examples:
> Render failed
>   found instead
>   found instead
> Render failed
yep ... confirmed both these items
> Povray: 3.7 RC3
32 bit OpenSuse ... up to date developers copy
Date: 19 Jul 2011 11:22:00
Message: <4e25a118$1@news.povray.org>
honestly never noticed before but (thud) it's /not/ just picking on the
cases mentioned by the original poster ... try specifying scale like this:
<scale 1,0.5,1>
Date: 19 Jul 2011 18:40:56
Message: <4e2607f8@news.povray.org>
Ok, I also see it on Window version. Never look at errors there
because they appears in the status bar anyway - and only once ;)
Date: 20 Jul 2011 15:30:17
Message: <4e272cc9@news.povray.org>
>> the cases mentioned by the original poster ... try specifying scale
>> like this:
They probably appears twice, but only one is ever displayed, so you
can't notice.
