POV-Ray : Newsgroups : povray.beta-test : ini file - Input_File_Name requires extension Server Time
26 Oct 2025 15:31:04 EDT (-0400)
  ini file - Input_File_Name requires extension (Message 1 to 10 of 12)
Subject: ini file - Input_File_Name requires extension
Date: 21 Jun 2010 20:00:01
Message: <web.4c1ffc789becd6c8bba8fbcd0@news.povray.org>
POV-Ray for Windows v3.7 beta 37a (64-bit)
ini file requires extension, whereas 3.6 did not.
i.e., Input_File_Name=scene worked under 3.6, but the beta requires
Input_File_Name=scene.pov
Subject: Re: ini file - Input_File_Name requires extension
Date: 22 Jun 2010 11:32:48
Message: <4c20d7a0@news.povray.org>
Hmm, you say ini file and show and example scene file. Please provide a
clear report saying what you expect and what happens instead.
	Thorsten
Date: 23 Jun 2010 22:48:45
Message: <4c22c78d$1@news.povray.org>
> Thorsten
No, he showed the example syntax he provided is used for INI files. See
"3.1.2.5.2  Input File Name".
Also, the docs say "If you do not have an extension then .pov is
assumed", which I assume is the problem he's reporting.
http://isometricland.com
Date: 24 Jun 2010 06:37:03
Message: <4c23354f$1@news.povray.org>
works fine for me linux-beta37c ... I have Work.ini that contains my
basic setup:
Display_Gamma=2.2
Input_File_Name=Work
Output_File_Name=/povfiles/
+fn
+wt4
Library_Path="/users/ash/POV-Ray/Source/"
Library_Path="/users/ash/POV-Ray/Source/Contributed/DF3Files"
Library_Path="/users/ash/POV-Ray/Source/Contributed/Proceduralize"
Library_Path="/users/ash/POV-Ray/Source/Contributed/Lattice/"
Library_Path="/users/ash/POV-Ray/Images"
Library_Path="/users/ash/POV-Ray/Includes"
then bash script that I run from command line:
povray Work Options[SomeAA] Options[RadiosityLoad] Options[Pause] +w800
+h600
note: from the command-line if no extension is given 'INI' is assumed
Jim
Date: 24 Jun 2010 11:28:06
Message: <4c237986$1@news.povray.org>
>> Thorsten
He says the INI file requires an extension. The syntax he showed should
work, and he did not say it doesn't. Hence he needs to clarify what the
problem is.
	Thorsten
Date: 24 Jun 2010 13:12:19
Message: <4c2391f3$1@news.povray.org>
> problem is.
... and my example shows that it does indeed work ... least ways for me ;-)
Date: 25 Jun 2010 07:48:05
Message: <4c249775@news.povray.org>
"jberry02" <nomail@nomail> schreef in bericht
news:web.4c1ffc789becd6c8bba8fbcd0@news.povray.org...
the line:
works well in version 3.7 for me. No need to add .pov
Date: 28 Jun 2010 22:30:01
Message: <web.4c295a08949a9ca3bba8fbcd0@news.povray.org>
> problem is.
OK - let me try to be more specific.
The syntax I showed used to work under prior versions of POV-Ray, and I was
expecting it to work under the 3.7 beta, but it fails.
First, note that this is the Windows version.
Second the issue is not with opening the ini file, but with opening the scene
file from within the ini file.
I have a scene.ini file, that has a line:
under POV-Ray 3.5 *and* POV-Ray 3.6, the scene defined in the file scene.pov is
rendered properly using the parameters specified in the scene.ini file.  The ini
file is opened from the POV-Ray GUI, and run using the "Run" button.
under POV-Ray 3.7, I get an error - I originally thought that it was simply not
looking for scene.pov (i.e., it wasn't adding the .pov extension when trying to
open the scene file), but looking closer the error is *actually*:
Input file 'C:\[...]\scene' not found; cannot determine I/O permission for
write.
Failed to start render: Cannot open file.
In other words, it appears that the problem is that it isn't adding the default
..pov extension when it is trying to do the I/O permission check.  I do not have
any special I/O permisssions configured for any version of POV-Ray (I get the
pop-up dialogs), and this is a change in behavior from 3.6 to the current beta
of 3.7.  The scene.pov file is not in any of the POV-Ray directories - it is in
a separate tree where I keep my scene files.
I hope this is clearer.
Date: 29 Jun 2010 03:09:42
Message: <4c299c36@news.povray.org>
news:web.4c295a08949a9ca3bba8fbcd0@news.povray.org...
> scene.pov is
> The ini
> simply not
> trying to
> write.
My guess: you may have to add the path to the scene.pov file. Obviously, the
ini and the pov files are not in the same directory, and the path is not in
your povray.ini
Date: 29 Jun 2010 12:32:35
Message: <4c2a2023$1@news.povray.org>
Am 29.06.2010 04:27, schrieb jberry02:
> write.
Having looked at it in a debugger, I can confirm that there is a
problem, and that you don't seem to be far off the mark:
The error occurs when POV-Ray tries to determine the I/O permissions for
the /output/ file. If that isn't explicitly specified with a path,
POV-Ray will try to get the path from the input file; however, it will
take the unprocessed parameter (in the sample case "scene") rather than
the file name POV-Ray makes of it ("scene.pov"), and then attempts to
get the full /long/ path name of the file (remember the good old 8.3
filenames for compatibility with 16-bit programs?), which only works
when the file exists.
Would you mind submitting a bug report to <http://bugs.povray.org>?
