POV-Ray : Newsgroups : povray.beta-test : Benchmark.pov update before release Server Time
30 Jun 2024 13:34:40 EDT (-0400)
  Benchmark.pov update before release (Message 1 to 10 of 26)
Subject: Benchmark.pov update before release
Date: 23 May 2010 10:35:00
Message: <web.4bf93c67dc8a8fde177b3660@news.povray.org>
Just a reminder that the included scenes\advanced\benchmark.ini/pov file is
diferent from the winpov menu render\run benchmark. The picture looks diferent.
Would be nice to match these up before release.
Added to flyspray bug reporting.
Stephen S
Subject: Re: Benchmark.pov update before release
Date: 23 May 2010 14:33:10
Message: <4bf974e6$1@news.povray.org>
> Stephen S
It would be good to remove at least one of those lines from benchmark.ini:
Display=Off
This disable the preview.
Output_To_File=Off
This disable saving the resulting image.
As it is now, there is NO preview and the image is NOT saved anywhere.
Date: 23 May 2010 14:41:33
Message: <4bf976dd$1@news.povray.org>
> Display=Off
> Output_To_File=Off
There is a "benchmark_Display.ini" which has the settings:
;Buffer_Output=Off
;Buffer_Size=0
Display=On
Output_To_File=On
Best Regards,
Date: 23 May 2010 14:48:12
Message: <4bf9786c$1@news.povray.org>
That is kind of the point of a processor benchmark and intentional :-)
	Thorsten
Date: 23 May 2010 15:24:31
Message: <4bf980ee@news.povray.org>
  How much overhead would displaying the image cause in reality? After all,
it would be nicer to see the image being rendered instead of just some
percentage...
Date: 23 May 2010 15:36:45
Message: <4BF983CE.5040602@aolDOT.com>
> percentage...
My Intel Core2 Duo 2.20GHz 3 Gig ram, laptop rendered the benchmark in
39m 40s with benchmark_Display.ini and 17m 56s with benchmark.ini.
Coincidently after a post by Stephen on another forum I checked it. I
did have other programs running but was not actively using them.
Best Regards,
Date: 23 May 2010 15:37:02
Message: <4bf983de$1@news.povray.org>
> percentage...
Well, the overhead would not be much indeed. But that isn't the problem. The
problem is that it cannot be predicted how much overhead it uses, and it
will depend on the GPU (if any). Running this on a system meant as a server,
which is usually fast running headless might add bias of a few percent
consistently even when doing multiple runs...
Or imagine a slow CPU and an X display over an encrypted connection. The
data transfer could draw so much CPU power...
Or a million of other alternative scenarios that could make the benchmarking
go wrong...
In short: No display and no disk output simply eliminates two random
variables from the measurement.
	Thorsten
Date: 23 May 2010 15:52:17
Message: <4bf98771$1@news.povray.org>
Am 23.05.2010 20:33, schrieb Alain:
> Display=Off
> Output_To_File=Off
This is by design. The benchmark is /only/ a benchmark of the render
engine, and any output activity is /not/ part of what it should measure.
Date: 23 May 2010 16:00:01
Message: <web.4bf9890a80488a8c1e3652a40@news.povray.org>
> ;Buffer_Output=Off
> ;Buffer_Size=0
> Display=On
> Output_To_File=On
> Best Regards,
>  Stephen
I don't have this file, but that was what I changed.
Note: the internal benchmark lists only 44 total objects, and the benchmark.ini
when run lists about 172 objects. There is also a big difference in photon time.
I don't think this has anything to do with display or saveing files.
Stephen S
Date: 24 May 2010 09:17:59
Message: <4bfa7c87@news.povray.org>
  Displaying the image while rendering slows down rendering speed to half?
I can't believe that. There must be an error somewhere.
