POV-Ray : Newsgroups : povray.beta-test : Windows 3.7b36, render window, changes Server Time
28 Sep 2024 21:17:21 EDT (-0400)
  Windows 3.7b36, render window, changes (Message 1 to 2 of 2)
Subject: Windows 3.7b36, render window, changes
Date: 21 Mar 2010 20:35:01
Message: <web.4ba6babfe357cbe9701a565a0@news.povray.org>
The behaviour of the render window has changed in the 3.7 versions over the 3.6
versions. Opinions?
Gray scale output:
In 3.7 .ini file,
Output_to_File = On
Output_File_Type = N
Grayscale_Output=true
Display = On
Gives a color render window, and a gray scale saved image.
In 3.6 global settings
hf_gray_16
Gives a gray scale render window, and a gray scale saved image.
Partial ouput, start end column/row and radiosity (pretrace_start/end):
In 3.7 .ini file,
+ac +sc0.378717 +sr0.526882 +ec0.522692 +er0.679570
for example.
Gives the area in question and 'may' give radiosity blocks to the right and
bottom.
In 3.6 .ini file,
for example.
Gives the area in question only.
Stephen S
Subject: Re: Windows 3.7b36, render window, changes
Date: 21 Mar 2010 22:19:15
Message: <4ba6d3a3$1@news.povray.org>
> versions. Opinions?
> Gray scale output:
> In 3.7 .ini file,
> Output_to_File = On
> Display = On
> hf_gray_16
Well, actually the render window behavior has not changed: In both
versions, preview is color if the hf_gray_16 is absent - which just
happens to be enforced by 3.7 ;-)
But I guess it makes sense to change POV-Ray 3.7 interpretation of the
new Grayscale_Output option so that it affects both file and preview
output, as it is such a fundamental setting that it goes beyond ordinary
file format options.
> In 3.7 .ini file,
> for example.
> bottom.
> In 3.6 .ini file,
> for example.
This is a side effect of the architectural changes in POV-Ray 3.7, and I
guess nobody has paid attention to this detail before. I guess it should
be possible to fix, but some thought will have to go into it.
