POV-Ray : Newsgroups : povray.beta-test : Crash - Report for POV-Ray-3.7.0.beta.34.msvc9-sse2.win32-4AF347BE.dmp Server Time
28 Mar 2026 05:13:03 EDT (-0400)
  Crash - Report for POV-Ray-3.7.0.beta.34.msvc9-sse2.win32-4AF347BE.dmp (Message 1 to 1 of 1)
Subject: Crash - Report for POV-Ray-3.7.0.beta.34.msvc9-sse2.win32-4AF347BE.dmp
Date: 5 Nov 2009 17:40:01
Message: <web.4af353b8493121263b8e68b80@news.povray.org>
Analysis Summary
Type  Description  Recommendation
  Error  WARNING - DebugDiag was not able to locate debug symbols for
pvengine-sse2.exe, so the information below may be incomplete.
In POV-Ray-3.7.0.beta.34.msvc9-sse2.win32-4AF347BE.dmp the assembly instruction
at pvengine_sse2+1bfbbd in C:\Users\Capn
Snappy\AppData\Roaming\POV-Ray\v3.7\bin\pvengine-sse2.exe from Persistence of
Vision Raytracer Pty. Ltd. has caused an access violation exception (0xC0000005)
when trying to read from memory location 0x0000001c on thread 11
 Please follow up with the vendor Persistence of Vision Raytracer Pty. Ltd. for
C:\Users\Capn Snappy\AppData\Roaming\POV-Ray\v3.7\bin\pvengine-sse2.exe
  Information  DebugDiag determined that this dump file
(POV-Ray-3.7.0.beta.34.msvc9-sse2.win32-4AF347BE.dmp) is a crash dump and did
not perform any hang analysis. If you wish to enable combined crash and hang
analysis for crash dumps, edit the CrashHangAnalysis.asp script (located in the
DebugDiag\Scripts folder) and set the g_DoCombinedAnalysis constant to True.
  Warning
DebugDiag failed to locate the PEB (Process Environment Block) in
POV-Ray-3.7.0.beta.34.msvc9-sse2.win32-4AF347BE.dmp, and as a result, debug
analysis for this dump may be incomplete or inaccurate.
 It is recommended that you get another dump of the target process when the
issue occurs to ensure accurate data is reported
 Analysis Details
Table Of Contents
   Faulting Thread
   Faulting Module Information
Type of Analysis Performed    Crash Analysis
Machine Name
Operating System    Windows Vista Service Pack 2
Number Of Processors
Process ID    4848
Process Image    C:\Users\Capn
System Up-Time    00:00:00
Process Up-Time    00:26:02
Thread 11 - System ID 5092
Function      Arg 1      Arg 2      Arg 3    Source
pvengine_sse2+1bfbbd      00000000      00000000      00000000
PVENGINE_SSE2+1BFBBDWARNING - DebugDiag was not able to locate debug symbols for
Module Information
Image Name:  C:\Users\Capn
Snappy\AppData\Roaming\POV-Ray\v3.7\bin\pvengine-sse2.exe    Symbol Type:  None
Base address:  0x00400000    Time Stamp:  Sun Aug 16 20:56:23 2009
Checksum:  0x004613fb    Comments:  May only be used or distributed under the
terms of the POV-Ray licence.
COM DLL:  False    Company Name:  Persistence of Vision Raytracer Pty. Ltd.
ISAPIExtension:  False    File Description:  POV-Ray for Windows
ISAPIFilter:  False    File Version:  3.7
Managed DLL:  False    Internal Name:  PVEngine
VB DLL:  False    Legal Copyright:  Copyright (c) 1991-2003 POV-Team, 2003-2009
Persistence of Vision Raytracer Pty. Ltd. All Rights Reserved. May only be used
or distributed under the terms of the POV-Ray licence.
Loaded Image Name:  pvengine-sse2.exe    Legal Trademarks:  POV-Ray(tm) is a
trademark of Persistence of Vision Raytracer Pty. Ltd.
Mapped Image Name:  C:\Users\Capn
Snappy\AppData\Roaming\POV-Ray\v3.7\bin\pvengine-sse2.exe    Original filename:
PVEngine.EXE
Module name:  pvengine_sse2    Private Build:
Single Threaded:  False    Product Name:  POV-Ray
Module Size:  4.68 MBytes    Product Version:  3.7
Symbol File Name:  pvengine-sse2.exe    Special Build:  &
 Script Summary
Script Name  Status  Error Code  Error Source  Error Description  Source Line
CrashHangAnalysis.asp  Completed
