POV-Ray : Newsgroups : povray.beta-test : --betacode problem with 3.7.0 beta 33 Server Time
26 Mar 2026 21:50:11 EDT (-0400)
   --betacode problem with 3.7.0 beta 33 (Message 1 to 3 of 3)
Subject: --betacode problem with 3.7.0 beta 33
Date: 14 Sep 2009 23:30:00
Message: <web.4aaf097b33b2706f8aa77e7f0@news.povray.org>
Hello
I compiled and installed 3.7 beta 33 without errors (eventually). Beta 34 source
for Unix isn't available as far as I can see and 33 has expired. However, the
--betacode fix isn't working for me:
play@play-desktop /usr/local/share/povray-3.7 $ povray --betacode
1432718284
play@play-desktop /usr/local/share/povray-3.7 $ POVRAY_BETA=1432718284
play@play-desktop /usr/local/share/povray-3.7 $ echo $POVRAY_BETA
1432718284
povray: this pre-release version of POV-Ray for Unix has expired
Linux 2.6.28-14-generic #47-Ubuntu SMP x86_64 GNU/Linux
Are the above commands correct? Many thanks,
Dave W.
Subject: Re: --betacode problem with 3.7.0 beta 33
Date: 15 Sep 2009 05:29:40
Message: <4aaf5e84$1@news.povray.org>
Merging the beta 34 source code for Windows into your copy of the beta
33 source code should get you to something. That's how I benchmark and
regression-test the POV-Ray code I'm presently working on (I develop on
a Windows machine, but due to easier scripting I run bulk tests on a
Debian Linux machine instead - which also gives me confidence that the
code I'm writing is portable.)
This might not work for version increments where source files are added
or removed, but that's only seldom the case at present.
> 1432718284
> 1432718284
I think you will need to "export POVRAY_BETA" as well, so that the shell
does not keep the environment variable a personal secret, but actually
passes it on to POV-Ray.
To make sure you don't introduce any typos, you can also combine the
first two commands to:
   POVRAY_BETA=`povray --betacode`
Date: 15 Sep 2009 09:48:33
Message: <4aaf9b31$1@news.povray.org>
	Beta.34 is now available online.
	You have to set an environment variable:
export POVRAY_BETA=value
	- NC
