POV-Ray : Newsgroups : povray.beta-test : [unix] ./configure --without-libjpeg has no effect in povray-3.7.0.beta.33 Server Time
17 Nov 2025 12:48:44 EST (-0500)
  [unix] ./configure --without-libjpeg has no effect in povray-3.7.0.beta.33 (Message 1 to 3 of 3)
Subject: [unix] ./configure --without-libjpeg has no effect in povray-3.7.0.beta.33
Date: 3 Sep 2009 18:30:00
Message: <web.4aa042277c842d4ef99d05c80@news.povray.org>
When attempting to install povray-3.7.0.beta.33 as a non-privileged user the
first time through, I thought I'd just ditch the file formats without libraries
already installed.  But no, that was not actually an option as configure aborted
with the same libjpeg not found error after specifying --without-libjpeg.
Though I didn't keep the log, I saved a copy of the exact command used.
.../configure COMPILED_BY="David Wagner <hon### [at] handbasketorg>"
--prefix=/home/xlw295/povray --with-boost=/home/xlw295/povray_src/boost_1_40_0
--without-libjpeg --enable-static
I worked around the problem by compiling and installing libjpeg (and libtiff a
few minutes later) in my home directory and figuring out exactly what config
was looking for in the path.
There seem to be some inconsistencies to where the --with-xxx paths are supposed
to point; --with-jpeg and --with-tiff need to point to the whatever/lib
directory, while --with-boost points one level higher.
Subject: Re: [unix] ./configure --without-libjpeg has no effect in povray-3.7.0.beta.33
Date: 4 Sep 2009 05:19:47
Message: <4aa0dbb3$1@news.povray.org>
waggy wrote:
configure aborted
	You need to read the INSTALL file so as to find out which additional option
you forgot to specify to make that one work properly.
	- NC
Subject: Re: [unix] ./configure --without-libjpeg has no effect in povray-3.7.0.beta=
Date: 4 Sep 2009 08:50:00
Message: <web.4aa10c2488706962f99d05c80@news.povray.org>
Thanks for pointing that out.
I see what caused my confusion.  Since I'm putting this on a system at a public
university, when I read the install file I paid particular attention to the
licensing terms which put in no uncertain terms that special permission is
needed to redistribute the beta.  So it didn't stick in my silly little head
that the default of NON_REDISTRIBUTABLE_BUILD is yes.
