POV-Ray : Newsgroups : povray.beta-test : How to build POVRay 3.7.33 using Intel compiler Server Time
15 Jan 2026 19:23:00 EST (-0500)
  How to build POVRay 3.7.33 using Intel compiler (Message 1 to 6 of 6)
Subject: How to build POVRay 3.7.33 using Intel compiler
Date: 14 Jul 2009 01:35:03
Message: <web.4a5c1822b1019aa671414fda0@news.povray.org>
Hi guys,
Who has an experience to build POVRay 3.7.33 using Intel compiler under
MSVS2008?
I can successfully built 3.7.32 using Intel compiler with MSVS2008 but I am
fails in 3.7.33 beta.
The error message like below:
1>ipo-3: error #11017: Cannot open libboost_date_time-iw-mt-s-1_37.lib
1>ipo-3: error #11017: Cannot open libboost_thread-iw-mt-s-1_37.lib
1>ipo-3: remark #11004: starting multi-object compilation
1>ipo-3: remark #11005: generating object file ipo_9726obj3.obj
1>xilink: executing 'link'
1>LINK : fatal error LNK1104: cannot open file
'libboost_thread-iw-mt-s-1_37.lib'
1>Build log was saved at "file://C:\Documents and Settings\wchen18\My
Documents\POV-Ray\window\povwin-src-3.7\windows\vs9\build\povwin\Win32-Release\BuildLog.htm"
1>povwin - 838 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 7 up-to-date, 0 skipped ==========
Thanks,
Wise
Subject: Re: How to build POVRay 3.7.33 using Intel compiler
Date: 14 Jul 2009 11:20:00
Message: <web.4a5ca1d8a1018f325fee4dc70@news.povray.org>
Did you check that the BOOST_ROOT environment variable is properly set? And that
the .lib files do exist there (in "lib" or "lib64" subdirectory, depending on
your target architecture), for that matter?
Date: 16 Jul 2009 01:05:04
Message: <web.4a5eb3f5a1018f3271414fda0@news.povray.org>
Thanks,
Now I found that I have to build boost using Intel compiler first and then I can
build POVRay project using Intel compiler for POVRay 3.7.33 beta(3.7.22 has no
this request).
But I still met lots of error LNK2001 messages like below:
1>------ Build started: Project: povwin, Configuration: Release Win32 ------
1>Linking... (Intel C++ Environment)
1>ipo: remark #11000: performing multi-file optimizations
1>ipo-1: remark #11004: starting multi-object compilation
1>ipo-1: remark #11005: generating object file ipo_30366obj1.obj
1>ipo-2: remark #11004: starting multi-object compilation
1>ipo-2: remark #11005: generating object file ipo_30366obj2.obj
1>ipo-3: remark #11005: generating object file ipo_30366obj3.obj
1>LINK : error LNK2001: unresolved external symbol _POVWINStartup
1>ipo_30366obj1.obj : error LNK2001: unresolved external symbol "public: virtual
void * __thiscall std::basic_ifstream<char,struct std::char_traits<char>
>::`vector deleting destructor'(unsigned int)"
(??_E?$basic_ifstream@DU?$char_traits@D@std@@@std@@UAEPAXI@Z)
1>ipo_30366obj2.obj : error LNK2001: unresolved external symbol "public: virtual
1>ipo_30366obj3.obj : error LNK2001: unresolved external symbol "public: virtual
Who know how to find this error of 'unresolved external symbol _POVWINStartup'
etc.?
Thanks,
Wise
Date: 4 Aug 2009 13:30:00
Message: <web.4a786f7aa1018f3264c007780@news.povray.org>
> Thanks,
> this request).
> etc.?
> Thanks,
> Wise
I had the same problem.
http://software.intel.com/en-us/articles/how-to-build-povray-37-beta-for-window-version/
I suggest you scroll to the bottom of the page or just do the following:
"   1. VS2008 does not support any version of windows prior to Windows 2000
   2. right click povwin project, choose properties-, then expand "
configuration properties" followed by "C/C++" and then "Preprocessor".
   3. Change the values of WINVER and _ WIN32_WINNT to appropriate value
depending on the OS version.
   4. The values to be set can be found at:
http://msdn2.microsoft.com/en-us/library/6sehtctf.aspx
   5. Please remove IlmImf_d.lib iex_d.lib ilmthread_d.lib imath_d.lib
half_d.lib from Additional Dependencies from Input of Linker in povwin Property
Pages in povray project if the building project met a linker error.
However, the beta release has expired as of August 1 which is another issue.
Date: 4 Aug 2009 14:52:01
Message: <4a788351$1@news.povray.org>
>> etc.?
>> Thanks,
>> Wise
I guess Wise knows that article quite well... (hint: just scroll to the
*very* bottom of that page ;-) )
Date: 4 Aug 2009 16:35:01
Message: <web.4a789a7ea1018f3264c007780@news.povray.org>
> >> etc.?
> >> Thanks,
> >> Wise
Hehe wow. I guess you're right. I just came across it and thought I'd share.
