POV-Ray : Newsgroups : povray.beta-test : Underlinking problem (second post) Server Time
4 Mar 2026 03:47:15 EST (-0500)
  Underlinking problem (second post) (Message 1 to 4 of 4)
Subject: Underlinking problem (second post)
Date: 7 Jan 2009 10:45:01
Message: <web.4964ccfdfd32c5e99335918f0@news.povray.org>
Hi folks,
I'm using Mandriva and there is by default a lot of work to trace down the
underlinking problems in the distribution. As a consequence it helps in finding
misses in the headers and so far, i've found some (see below). I've also
precised some singulariteis (for "exception", where there was an ambiguity
between "exception" from the system, and "exception" from the boost library).
Please have a look at the changes since i think they may prove useful for others
as well (and i'm far from being an expert so i may have add some duplicates).
With these modifications, the code compiles fine (on beta29, x86-64 build). I
presume some also come from includes missing in the boost library (in the
thread.hpp, boost/thread/condition.hpp should be present), but i've patched
povray for now. Mandriva package is lib64boost-devel-1.36.0-1mdv2009.0.
Cheers,
diff -Naup ./source/backend/support/task.cpp~ ./source/backend/support/task.cpp
--- ./source/backend/support/task.cpp~  2009-01-06 16:13:03.000000000 +0100
+++ ./source/backend/support/task.cpp   2009-01-06 16:27:18.000000000 +0100
@@ -93,7 +93,7 @@
 #include <boost/thread.hpp>
 #include <boost/bind.hpp>
-#include <boost/exception.hpp>
+#include <exception>
 // frame.h must always be the first POV file included (pulls in platform
config)
 #include "backend/frame.h"
@@ -244,7 +244,7 @@ void Task::TaskThread(const function0<vo
                        FatalErrorHandler(e);
                        failed = e.code(kUncategorizedError);
-               catch(exception& e)
+               catch(std::exception& e)
                        FatalErrorHandler(POV_EXCEPTION_STRING(e.what()));
                        failed = kUncategorizedError;
@@ -272,7 +272,7 @@ void Task::TaskThread(const function0<vo
@@ -297,7 +297,7 @@ void Task::TaskThread(const function0<vo
diff -Naup ./source/backend/support/taskqueue.h~
../source/backend/support/taskqueue.h
--- ./source/backend/support/taskqueue.h~       2008-02-04 15:28:48.000000000
+0100
+++ ./source/backend/support/taskqueue.h        2009-01-06 15:01:46.000000000
+0100
@@ -98,6 +98,7 @@
 #include <boost/shared_ptr.hpp>
+#include <boost/thread/condition.hpp>
 #include "base/povmscpp.h"
 #include "backend/support/task.h"
diff -Naup ./vfe/unix/unixconsole.cpp~ ./vfe/unix/unixconsole.cpp
--- ./vfe/unix/unixconsole.cpp~ 2008-10-08 01:06:27.000000000 +0200
+++ ./vfe/unix/unixconsole.cpp  2009-01-07 15:21:05.000000000 +0100
@@ -254,7 +254,7 @@ void PrintStatusChanged (vfeSession *ses
 void PrintBeta(int argc, char **argv)
-       const int sph = 3600, spd = 86400, spw = 604800;
+  /*   const int sph = 3600, spd = 86400, spw = 604800;
        time_t current_time = time(NULL);
        if (current_time > EXPIRE_AT)
@@ -295,7 +295,7 @@ void PrintBeta(int argc, char **argv)
        fprintf(stderr,
                "%s: this pre-release version of POV-Ray for Unix expires in %d
day(s) and %d hour(s)\n",
                PACKAGE, current_time/spd, (current_time % spd)/sph
 void PrintVersion(void)
        fprintf(stderr,
diff -Naup ./vfe/vfe.h~ ./vfe/vfe.h
--- ./vfe/vfe.h~        2008-02-04 15:28:52.000000000 +0100
+++ ./vfe/vfe.h 2009-01-07 15:03:59.000000000 +0100
@@ -94,9 +94,11 @@
 #include <queue>
 #include <cassert>
 #include "syspovconfigfrontend.h"
 #include <boost/format.hpp>
 #include <boost/function.hpp>
 #include "base/povms.h"
@@ -113,6 +115,7 @@
 namespace vfe
   using namespace std;
+  using namespace boost;
   using namespace pov_frontend;
   class vfeException : public runtime_error
diff -Naup ./vfe/vfesession.h~ ./vfe/vfesession.h
--- ./vfe/vfesession.h~ 2008-05-27 16:39:41.000000000 +0200
+++ ./vfe/vfesession.h  2009-01-06 16:45:22.000000000 +0100
@@ -98,6 +98,7 @@ namespace vfe
   using namespace pov_base;
   // class IOPath
diff -Naup ./vfe/vfesession.cpp~ ./vfe/vfesession.cpp
--- ./vfe/vfesession.cpp~       2009-01-06 16:38:11.000000000 +0100
+++ ./vfe/vfesession.cpp        2009-01-07 15:06:53.000000000 +0100
@@ -695,7 +695,7 @@ void vfeSession::WorkerThread()
     m_Failed = true;
     m_LastError = vfeCaughtException;
-  catch (exception&)
+  catch (std::exception&)
     m_Failed = true;
diff -Naup ./vfe/vfecontrol.cpp~ ./vfe/vfecontrol.cpp
--- ./vfe/vfecontrol.cpp~       2008-05-27 16:39:40.000000000 +0200
+++ ./vfe/vfecontrol.cpp        2009-01-07 15:05:13.000000000 +0100
@@ -489,7 +489,7 @@ int vfeSession::StartRender()
     if (!m_Frontend->Start (m_RenderOptions.m_Options))
       return (m_LastError = vfeFailedToSendRenderStart) ;
-  catch (exception& e)
+  catch (std::exception& e)
     if (dynamic_cast<pov_base::Exception *> (&e) != NULL)
       m_RenderErrorCode = dynamic_cast<pov_base::Exception *> (&e)->code() ;
Subject: Re: Underlinking problem (second post)
Date: 7 Jan 2009 11:10:01
Message: <web.4964d359751d41f6bdc576310@news.povray.org>
>         fprintf(stderr,
This one seems to be the only dupe... and seems to fix a totally different issue
Date: 7 Jan 2009 12:20:00
Message: <web.4964e31a751d41f69335918f0@news.povray.org>
> >         fprintf(stderr,
Right, i just forgot i tried to hack the "expired issue", just before seing
there is the --beta-code option :-)
Date: 8 Jan 2009 01:43:01
Message: <4965a075$1@news.povray.org>
Thanks for the patches - ironically I only just went through all that
myself since I upgraded to the latest boost while doing the most recent
windows release. I haven't put the source up yet, though. Probably ought to ...
-- Chris
