POV-Ray : Newsgroups : povray.beta-test : beta 29 linux problems... Server Time
4 Mar 2026 03:49:09 EST (-0500)
  beta 29 linux problems... (Message 1 to 7 of 7)
Subject: beta 29 linux problems...
Date: 4 Jan 2009 11:35:00
Message: <web.4960e481cf8be8c9360c96990@news.povray.org>
Ok, I've found the time-limit workaround, however when ever I try to render a
scene povray outputs this:
povray: this pre-release version of POV-Ray for Unix expires in 5 day(s) and 5
hour(s)
Unknown error code
Has anyone else had this problem?
Subject: Re: beta 29 linux problems...
Date: 4 Jan 2009 12:23:15
Message: <4960f083@news.povray.org>
> render a scene povray outputs this:
> and 5 hour(s)
> Unknown error code
There was info about this problem in this newsgroup *yesterday*!
There is no workaround anymore, beta 29 has permanently expired this time.
Wait for beta 30.
Date: 4 Jan 2009 13:10:00
Message: <web.4960f9b035166235360c96990@news.povray.org>
this seemed to work:
#povray --betacode
829964851
#POVRAY_BETA=829964851 povray
povray: this pre-release version of POV-Ray for Unix expires in 5 day(s) and 4
hour(s)
No input file provided
I doubt the unknown error-code thing has anything to do with the expiration.
Anyway, I just tried installing from source, and the same thing happens. Anyone
know of a line in a source file that can be changed? I had a little look for
myself, but couldn't find anything.
Date: 4 Jan 2009 14:28:45
Message: <49610ded@news.povray.org>
look in vfe.cpp at around line 751 (after "xtime_get(&t, TIME_UTC);") and
modify the following line to read as follows:
  if (t.sec > 1262296800)
This will set the hard timeout to 1 Jan 2010.
-- Chris
Date: 4 Jan 2009 23:45:01
Message: <web.49618e9a35166235c38b01850@news.povray.org>
It has. This is a slightly different mechanism than the renew-me-every-week one,
and this "unknown" error is the all-too-well known symptom of it.
If you don't want to wait for the beta 30 Linux binary, look in vfe.cpp.
VirtualFrontEnd::Start() is the thing you will want to patch.
Date: 29 Jan 2009 21:50:01
Message: <web.49826a7f3516623596066cf40@news.povray.org>
Where do I find file vfe.cpp - it doesn't seem to be installed. Is this file
required to be changed before compiling the program?
thanks a lot
Date: 30 Jan 2009 11:35:00
Message: <web.49832bda35166235bdc576310@news.povray.org>
It's one of POV-Ray's C++ source code files, so yes - if you want it to have any
effect, you need to compile afterwards...
