POV-Ray : Newsgroups : povray.beta-test : "configure" script broken in beta 29 (unix source package) Server Time
17 Nov 2025 18:25:39 EST (-0500)
  "configure" script broken in beta 29 (unix source package) (Message 1 to 7 of 7)
Subject: "configure" script broken in beta 29 (unix source package)
Date: 22 Dec 2008 13:55:00
Message: <web.494fe25d9d9e24ec569d0e9f0@news.povray.org>
Line 6446 of the "configure" script shipped with the beta 29 is broken; the line
reads:
    ax_compiler_version=`cat conftest.out | 's,.*[[:space:]],,'`
which is obviously nonsense, and should probably read instead:
    ax_compiler_version=`cat conftest.out | sed 's,.*[[:space:]],,'`
This doesn't show when using the standard settings, but gets in the way when
trying to configure for the Intel C++ compiler using the following settings:
../configure --prefix=/foo/bar COMPILED_BY="foobar" CXX=icpc
on a Debian "Etch" 4.0r5 AMD64 Linux using the 11.0 Intel(R)64 version of the
intel compiler.
Don't know whether this is a general autoconf bug though, or POV-Ray specific.
Subject: Re: "configure" script broken in beta 29 (unix source package)
Date: 22 Dec 2008 14:07:41
Message: <494fe57d@news.povray.org>
  I know nitpicking about "useless use of cat" is rather old, but would
it really hurt if that was written in the "kosher" way, ie:
    ax_compiler_version=`sed 's,.*[[:space:]],,' conftest.out`
  If nothing else, it's more efficient that way.
Date: 22 Dec 2008 15:25:00
Message: <web.494ff6b9496cddbdedb0f3170@news.povray.org>
Maybe it has something to do with compatibility? Maybe some exotic systems that
run into trouble with this 'kosher' approach?
Then again it just may have to do with Unix people's brain cells being
hard-wired to using pipes whenever they hear "sed", "grep", "awk" or similar.
Anyway, we're not talking about runtime performance of POV here, just some
installation thing that runs fast enough as it is.
Date: 22 Dec 2008 16:19:18
Message: <49500456@news.povray.org>
  There's no reason to not do it correctly.
Date: 22 Dec 2008 16:25:00
Message: <web.495004f9496cddbdedb0f3170@news.povray.org>
I don't know, maybe this is all generated by Autogen, which (if I understand the
concept correctly) would move this issue out of the scope of the POV team.
Date: 22 Dec 2008 16:39:17
Message: <49500904@news.povray.org>
> the line reads:
> when trying to configure for the Intel C++ compiler using the following
> settings:
> the intel compiler.
> specific.
If that line isn't in configure.ac (or configure.in, not sure what POV calls
it), it's an autoconf problem.
Date: 22 Dec 2008 19:20:56
Message: <49502ee8$1@news.povray.org>
	That's POV specific -- you know, typically the kind of things that tend to
happen in (though long-standing) beta software.
	Thanks for the report anyway  :)
	- NC
