POV-Ray : Newsgroups : povray.beta-test : Colors.inc Server Time
16 Feb 2026 22:26:42 EST (-0500)
  Colors.inc (Message 1 to 10 of 14)
Subject: Colors.inc
Date: 26 Sep 2008 11:15:04
Message: <web.48dcfc0b3fd17be45a89dbe40@news.povray.org>
I have a humble suggestion to expand the colors present in colors.inc.
The table below provides a list of the X11 colors supported by popular browsers:
http://www.w3.org/TR/css3-color/#svg-color
Would not it be useful to include it?
And the wonderful macro HTML2RGB, by Warp? :
http://news.povray.org/povray.newusers/message/%3C418699ac%40news.povray.org%3E/#%3C418699ac%40news.povray.org%3E
Thanks for your attention.
Regards
Subject: Re: Colors.inc
Date: 27 Sep 2008 04:10:00
Message: <web.48dde942a0db5d9add620c320@news.povray.org>
Yes, it would!
And - GOOD NEWS - it has been done years before, see HERE:
and look for KOLORS.INC and KOLORS2.inc
I haven't checked for ALL of the colors mentioned in your first link,
but a few random samples are all present, and much more...
Happy raytracing and a nice weekend
Karl
Date: 8 Oct 2008 11:05:02
Message: <web.48eccb18a0db5d9a525819430@news.povray.org>
I'm working on colors.inc to propose it as a new include for POV-Ray 3.7,
despite the fact that I am still quite ignorant, especially as regards POV-Ray.
Some colors of the "old" include have the same name but not the same parameters
of the colors recommended by the W3c consortium.
How can we solve the problem?
Perhaps in this way? :
#if (version=3.7) #declare Coral = rgb <1,127/255,80/255>;
#else #declare             Coral = rgb <1,0.498039,0>; #end
Thank you for your feedback.
Regards
Date: 8 Oct 2008 11:43:50
Message: <48ecd536$1@news.povray.org>
Le Wed, 08 Oct 2008 11:00:40 -0400, Carlo C. a modifié des petits morceaux
de l'univers pour nous faire lire :
> #if (version=3.7) #declare Coral = rgb <1,127/255,80/255>; #else
Beware of gamma... W3C probably has not the same gamma as povray now.
Things are fine for <1,0,0> / #FF0000, but #C00000 might be only
<0.5,0,0>, while #7F7F7F being only <0.25,0.25,0.25>
(fictional numbers here, check your gamma curves!)
To sum up, conversion from W3C colorspace might not be linear for a
povray include.
Getting colour which change from version is also a bad idea: you are not
parsing it each time you need it, but usually only once... what about
scenes with some parts in 3.6 and other parts in 3.7 ? How would you
handle that ?
Date: 9 Oct 2008 04:25:00
Message: <web.48edbf27a0db5d9a89e793780@news.povray.org>
> povray include.
> handle that ?
Thank you for your comments.
Gamma correction: Alas, I am not sufficiently prepared on this subject.
However ...
I have a Windows system, and my assumed_gamma is 2.2 by default.
If I want with POV-Ray a background Coral, and I put my picture in a HTML file
with the background of CSS set to Coral, I know with certainty that the two are
the same background.
Sure, maybe it's not correct to change the colors of the old colors.inc.
Perhaps a better solution would be then to add, for example:
X11_Coral = ... ?
I would be happy to your further clarification.
Greetings
Date: 9 Oct 2008 07:06:08
Message: <48ede5a0@news.povray.org>
  I thought the whole idea of gamma correction was that you *don't* have
to worry about whether <.75, .75, .75> "looks right". In other words,
<.75, .75, .75> should always look the same in all systems, assuming those
systems have a proper gamma correction set up. In other words, you don't
have to be modifying that value depending on which "gamma" is being used
but you are able to always use the same absolute value and let the target
system do the necessary corrections. Which is the whole idea of gamma
correction.
  You are reversing the situation completely and basically saying that
because of gamma correction you *must* always fine-tune that color value
by hand. I think that would completely nullify the whole idea of gamma
correction.
  Besides, if you want to change the gamma of the colors used in POV-Ray,
the correct place is not the color definitions themselves, but the assumed
gamma setting of POV-Ray ('assumed_gamma' global setting in pov3.6).
Date: 9 Oct 2008 07:44:33
Message: <48edeea1$1@news.povray.org>
POV works in linear colour space though, not gamma corrected.  So when you
supply colours or textures to POV, you need to inverse gamma correct them
first, to get correct results.
IMO POV should have an option to do this automatically, as people are used
to knowing what <0.75,0.75,0.75> looks like on their desktop (eg by using
Paint or HTML).  <0.75,0.75,0.75> in a POV colour statement or a texture
used by POV means something different currently.
Date: 9 Oct 2008 08:32:59
Message: <48edf9fa@news.povray.org>
  It has had that for a long time: assumed_gamma.
Date: 9 Oct 2008 09:01:20
Message: <48ee00a0$1@news.povray.org>
That only works at the output of the rendering engine though, it needs to
also apply the inverse to any colours/textures at the input of the rendering
engine.  Otherwise you need to do the inverse-gamma hack to images and
colours to make things look right.
eg try rendering background{ color rgb <255,128,64>/255}
If the user has chosen that colour to match something else outside of POV,
it's not going to work unless you turn off gamma correction in POV, which
would then mean any lighting in your scene will be wrong.
The point is, most users expect that entering a colour value or supplying an
image_map to be in their desktop colour space (ie already gamma corrected),
but POV treats these things as being in linear colour space.
Date: 9 Oct 2008 09:53:53
Message: <48ee0cf0@news.povray.org>
  No, assumed_gamma is used for all the input values. To modify the
output image, the display gamma command-line option is for that (this
is, AFAIK, what gets written to the PNG file when outputting to one).
