POV-Ray : Newsgroups : povray.beta-test : MP is amazing Server Time
29 Sep 2024 07:20:40 EDT (-0400)
  MP is amazing (Message 1 to 2 of 2)
Subject: MP is amazing
Date: 26 Aug 2008 16:40:00
Message: <web.48b4693544dd7dd45afe6fd0@news.povray.org>
The MP version of POVRay is absolutely exceptional and it is *frighteningly"
fast.
I rendered this image
http://www.calvert.ch/photo/still-life/raytrace/slides/calabiyau.jpg
with transparency and radiosity and in barely 8 minutes (log below).
Congratulations, this is a beautiful piece of engineering.
Preset INI file is 'C:\DOCUMENTS AND SETTINGS\MAURICE\APPLICATION
DATA\POV-RAY\V3.7\INI\POVRAY.INI'.
Preset source file is 'D:\POVRay\CalabiYau\calabiyau.pov'.
Rendering using command line '+A'.
Rendering with 8 threads.
Parser Options
  Input file: D:\POVRay\CalabiYau\calabiyau.pov
  Remove bounds........On
  Split unions.........Off
  Library paths:
    C:\Documents and Settings\maurice\Application Data\POV-Ray\v3.7\include
    C:\WINDOWS\Fonts
Parse Warning: This rendering uses the following experimental feature(s):
radiosity. The design and implementation of these features is likely to change
in future versions of POV-Ray. Full backward compatibility with the
current implementation is NOT guaranteed.
Parser Statistics
Finite Objects:       500000
Infinite Objects:          0
Light Sources:             1
Total:                500001
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 13.921 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  3 seconds (3.219 seconds)
              using 1 thread(s) with 3.218 CPU-seconds total
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
Render Statistics
Image Resolution 1200 x 1200
Pixels:          1544847   Samples:          217323   Smpls/Pxl: 0.14
Rays:          512466116   Saved:          99698909   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Triangle                    2567388479       246353126      9.60
Bounding Box               49954308188     12771734462     25.57
Shadow Ray Tests:         129105148   Succeeded:              50825479
Transmitted Rays:         191716446
Render Time:
  Photon Time:      No photons
  Radiosity Time:   0 hours  0 minutes  4 seconds (4.093 seconds)
              using 8 thread(s) with 31.370 CPU-seconds total
  Trace Time:       0 hours  7 minutes 45 seconds (465.250 seconds)
              using 8 thread(s) with 3662.138 CPU-seconds total
POV-Ray finished
CPU time used: kernel 1.95 seconds, user 3712.30 seconds, total 3714.25 seconds.
Elapsed time 488.80 seconds, CPU vs elapsed time ratio 7.60.
Render averaged 2946.01 PPS (387.70 PPS CPU time) over 1440000 pixels.
Subject: Re: MP is amazing
Date: 18 Sep 2008 07:44:44
Message: <48d23f2c@news.povray.org>
> fast.
Thanks for the feedback:)
-- Chris
